Choke Conversion
Old Jan 25, 2003 | 11:40 PM
78RangerXLT's Avatar
78RangerXLT
Choke Conversion
I read a previous post about the proper wiring of an electric choke..Anyways I got to thinking I have a motorcraft 2bbl carb with the thermal actuated choke and i would like to have the electric choke. My friend has a 79 T-Bird with the 351M like I have and he has the same carb, but on the choke he has a plug on it with wires coming off of it. Is there any way I can convert my choke the way it is now to an electric assisted or fully electric choke w/o purchasing a new carb all together? Thanks guys.
Old Jan 25, 2003 | 11:44 PM
Mil1ion's Avatar
Mil1ion
Choke Conversion
Yes,
Just get the black *electric choke housing* and a piece of wire and connect it to the stator terminal
Old Jan 25, 2003 | 11:51 PM
78RangerXLT
Choke Conversion
umm, one more thing. Where can i find this choke housing? at an auto parts store or junkyard?
Old Jan 26, 2003 | 10:59 AM
Mike W's Avatar
Mike W
Choke Conversion
If you can't find the Ford choke cap, use a Holley cap. It will fit. It has two terminals. One goes to ground. The other to the stator terminal. It is made for 12 volts but works fine on 7.
Old Jan 26, 2003 | 05:50 PM
tejomakash's Avatar
tejomakash
Choke Conversion
Why do you want to change? What are the advantages of electric over thermal?
Tery
Old Jan 26, 2003 | 09:22 PM
Mike W's Avatar
Mike W
Choke Conversion
The hot air pickup system is fine when it is new. I have had too much trouble with the tubes coming apart at the manifold. Since I did the electric conversion, the choke works everytime.
Old Jan 26, 2003 | 10:45 PM
Franklin2's Avatar
Franklin2
Choke Conversion
Well it's good to know a holley type electric housing will fit. I have not had a ford housing that has not burnt out on me. A long time ago I checked, and seemed to remember no one carried the housing, and the Ford dealer wanted an outrageous price. The housing just burnt out on my truck, so I decided to see if things have changed in the past few years. Nope. No one seems to carry it, and I checked with Ford and they wanted $65.00. I didn't want to, but bit the bullet and put a manual choke conversion on it. Boy I am really happy with it. It gets twice the gas mileage that it did with the broken auto choke. I also did something different this time that I usually don't do. I usually use the whole cable, running it through the firewall near the steering column, and routing it around to the choke. They never do work smoothly this way. This time I cut most of the cable off, and mounted it underneath the ash-tray. I drilled a hole right above the brace for the dash, and ran it directly to the carb. Boy it works so smooth! The only thing that bugs me is it wouldn't clear the original air cleaner. I modified the air cleaner to fit, but it's still not the way I want it.
Old Jan 27, 2003 | 08:50 AM
tejomakash's Avatar
tejomakash
Choke Conversion
So, the advantage to the electric choke is it is more reliable in the long run? I can put any ford or holley elect choke module on my Holley or Motorcraft carb? And all I have to do to hook it up is plug it to an electrical source that is charged only when the key is in the "on" position?
Considering the condition of my choke tubes, I think I have something to add to my "wanted" list.
Thanks, guys.
Tery
Old Jan 28, 2003 | 08:59 PM
Mike W's Avatar
Mike W
Choke Conversion
I forgot the part number but it was a standard Holley replacement cap. Was $26 a few years ago. I like manual chokes also, but you have to remember to pull them out and push them in. The electric choke was one of my better mods.
Old Feb 24, 2003 | 05:46 PM
Superchicken's Avatar
Superchicken
Choke Conversion
Franklin,
Where did you buy the manual choke kit? I'm interested in one for my '86 F150 I6 with the Carter carb.
Thanks!
Old Feb 24, 2003 | 10:07 PM
Mike W's Avatar
Mike W
Choke Conversion
You can buy a universal kit cheap at a parts store. The hardware is kind of flimsy but it will work.
1912barry
19
Sep 22, 2011 12:50 PM
80fordf150
20
Dec 1, 2010 03:56 AM
Duksrule
Jun 16, 2009 11:36 AM
86rustbucket
Mar 13, 2008 06:41 PM
wiznewski
Sep 17, 2003 05:00 AM
