electric choke
Old Sep 12, 2003 | 07:42 PM
wiznewski's Avatar
wiznewski
electric choke
I just purchased a Holley Carb 600cfm with an electric choke.
My last carb had a mannual choke.
How do I wire the electric choke on the new carb
Thanks
Old Sep 12, 2003 | 07:51 PM
DuckRyder's Avatar
DuckRyder
electric choke
Connect it to a 12v keyed power source.
NOT the coil.
It may have two terminals, if so it should have a short jumper which grounds somewhere on the carb.
It is polarity sensitive.
Old Sep 13, 2003 | 10:18 AM
Sunny_in_hollister's Avatar
Sunny_in_hollister
electric choke
The positve wire should go to the Stator terminal on the alternator. This has power only when the engine is turning.
Reggie
Old Sep 13, 2003 | 10:49 AM
DuckRyder's Avatar
DuckRyder
electric choke
Reggie
That would be ideal, if you can get it in there.
Old Sep 14, 2003 | 10:48 PM
Jsbiohazard's Avatar
Jsbiohazard
electric choke
I ran a wire to my fuse block that was keyed and it works fine. Just make sure the power turns off with the key or the choke will stay on all the time(not what you want).
Old Sep 15, 2003 | 06:43 AM
lee's Avatar
lee
electric choke
Hi,
I just completed going back to a manual from an electric on my Holley. The electric was a royal pain in the butt.
The problem is that it cools off way to fast. If for instance I pull into a gas station to fill her up, by the time I crank it to leave the choke had already cooled off enough that the engine would be at a high idle again. Really a pain if you make alot of stop and goes.
Take care,
Old Sep 15, 2003 | 07:00 AM
DuckRyder's Avatar
DuckRyder
electric choke
Originally posted by lee
Hi,
Take care,
That is an adjustment problem.
Old Sep 15, 2003 | 09:05 AM
Putt's Avatar
Putt
electric choke
I'll have to agree with DuckRyder on this, and the proper hook-up is the stator terminal. That way if the key is left on and the truck isn't running the choke has no power. It has also been my experience that Holleys in general do not need alot of choke to start cold. I have modified the choke plate on all mine.
Old Sep 16, 2003 | 02:40 PM
lee's Avatar
lee
electric choke
DuckRyder
Please "ed-u-ma-kate" me on this adjustment you speak of. I know how to rotate the large black choke cap to adjust how much choke is applied but how do you adjust the rate at which the bi-metallic element cools off?
Honestly, within 5 minutes of the engine being shut off my previous electric choke would have cooled off enough to cause the carb to go to high idle(choked) when re-cranked.
Inquiring minds want to know!
Thanks,
Old Sep 16, 2003 | 02:56 PM
DuckRyder's Avatar
DuckRyder
electric choke
What model number carb and what part number electric choke conversion kit?
Sounds to me like the vacuum source for pull off was bad.
Old Sep 16, 2003 | 08:04 PM
lee's Avatar
lee
electric choke
Hi,
A stock Holley 80508 750cfm Vacuum secondaries carb. Comes stock with electric choke so no conversion kit was needed.
Thanks,
Old Sep 16, 2003 | 08:46 PM
DuckRyder's Avatar
DuckRyder
electric choke
Hmmmm,
Nearly the same carb as my 3310 with electric conversion.
How cold is the weather when it is doing this? Mine takes 30 or so minutes to cool off to the point that it will fast idle again. The choke is set in the middle and it works perfectly. I have to think that there is a clog in the pull off system, or that the sping is either mis-installed or defective. Did you try positioning the choke all the way to lean and did it still do this?
Of course if you like the manual choke I guess it is a moot point, but I wouldn't trade mine.
Old Sep 17, 2003 | 05:00 AM
wiznewski's Avatar
wiznewski
electric choke
I got my holley in yesterday, Will hook wire to Stator.terminal.
Which terminal is it on the alt. what color wire?
The reason I am asking is I just installed a new alternator and want to make sure it is wired correctly.
Thanks
Viperfoxbat
Jul 25, 2016 10:56 AM
Black Helmet
WTB - Parts & other
Jun 26, 2016 01:28 PM
avellaneda13
15
Dec 7, 2015 11:10 AM
Mdc9966
Sep 16, 2015 11:20 AM
jons67
Jun 21, 2006 06:37 PM
