what is this part do
Old Mar 26, 2010 | 09:25 PM
1969furd's Avatar
1969furd
i have a problem, i have a 1979 f259 with a 351M engine, ther is 2 green vaccuum looking things on the water intake on the top of the water intake(will post pics in the morning) they appear at one time to have had hoses attachted to them , not sure were they went to. If i could get some idea i would appreciate it, there will be pics to follow. I think this is why i keep failing emission testing?
Old Mar 26, 2010 | 10:33 PM
ctubutis's Avatar
ctubutis
Does it look similar to this:
If so, it's a temperature-actuated vacuum control valve; the EGR and other emissions-
control devices are partially controlled by those things and this could very well be at least
part of why you keep failing the e-tests. There might be a sticker under your hood showing
the routing of the vacuum hoses and all of the associated devices.
You'll probably have better luck posting this in the 73-79 forum.
Old Mar 26, 2010 | 11:20 PM
1969furd's Avatar
1969furd
that is EXACTLY what they look like!!!! I will aske over there i was just figured here would be a good general area to start
Old Apr 2, 2010 | 11:30 PM
1969furd's Avatar
1969furd
can i just yabk this out and put in a bolt and call it good, or will this casue problems?
Old Apr 3, 2010 | 10:44 PM
ctubutis's Avatar
ctubutis
My father would tell me to use what's called a pipe plug. But a bolt should be OK so long as
you can keep it from leaking.
Old Apr 3, 2010 | 10:48 PM
1969furd's Avatar
1969furd
bolt with thread tape??? that would stop it from leakig right???
Old Apr 3, 2010 | 10:51 PM
ctubutis's Avatar
ctubutis
I don't know, try it and see. That hole will be a direct connection into the water jacket.
Old Apr 3, 2010 | 10:54 PM
1969furd's Avatar
1969furd
thanks, i will try that along with a gallon of anti freeeze.
Old Apr 4, 2010 | 09:35 PM
grclark351's Avatar
grclark351
a bolt won't work for long anyway, just get the right size pipe plug, they have tapered threads to make the seal where bolts are straight cut and the wrong pitch too
Old Apr 5, 2010 | 07:13 PM
neversosure's Avatar
neversosure
Heh heh heh he said bolt w/ teflon heh heh heh heh
Old Apr 14, 2010 | 01:55 AM
1969furd's Avatar
1969furd
any one know what size pipeplug?? i need to get this thing to pass emmissions!!!!!
Old Apr 15, 2010 | 11:54 PM
1969furd's Avatar
1969furd
any one have any ideas?
Old Apr 17, 2010 | 10:43 PM
grclark351's Avatar
grclark351
remove the part from the waterpump and take it with you to the local hardware store. in the plumbing aisle you'll find pipe plugs, some black iron, some galvanized, some brass, maybe even PVC. i'd use a brass pipe plug that matches the threads on the vacuum control part that used to be in the waterpump.
you said that you're having problems with emissions, is it because of a visual inspection, or just because the engine can't pass the sniff test?
what state and what kind of test?
Old Apr 17, 2010 | 10:47 PM
1969furd's Avatar
1969furd
Sniff test az
Old Apr 18, 2010 | 12:42 AM
grclark351's Avatar
grclark351
well if the tune-up parts are all good, firing on all 8... and the carb doesn't have problems leaking gas down the bbls... the most likely cause of failing the sniff is too much ignition advance. what i've done to pass is disconnect the vacuum hose and plug it, then set the base timing as low as i could but where it would still run ok. i got a monster built dual quad tunnel ram Cleveland through the lane that way
