Stroker Pistons- Oil Ring ????
Old Mar 26, 2010 | 03:16 AM
jamies460's Avatar
jamies460
Cool Stroker Pistons- Oil Ring ????
With these KB 860 pistons the ring set that came with them is a Speed Pro set- part number R-9332 5. I was wondering if any-one had used these before as I cant work out how the oil Rings work, they have two nylon buttons on each called Expander buttons, it states they butt up together then install the oil ring retaining ring ????? doe's the oil retaining ring go above or below the oil ring to help hold it in place.
Old Mar 26, 2010 | 11:01 AM
mark a.'s Avatar
mark a.
There should be two rings. One goes on top the other on the bottom.
Old Mar 27, 2010 | 01:04 AM
jamies460's Avatar
jamies460
Thanks mark a, I found the other set of oil retaining rings this morning and worked it out, only thing is one oil ring fits tightly while the other is a little loose.....
Lee250
Sep 4, 2010 07:33 AM
Argess
Feb 7, 2009 08:58 PM
KRD
Dec 14, 2007 07:01 AM
1978fordf250
Jul 30, 2007 09:53 PM
