starter wire broke
Old Mar 25, 2010 | 04:18 PM
zanks's Avatar
zanks
starter wire broke
and shorted out my truck (2001 7.3). It shut down in the middle of the road. I got it out of the road, but now all my gagues are going crazy and still want start after I replaced the wire. Anyone have an idea of what the short might have damaged?
Old Mar 25, 2010 | 04:50 PM
just another truck's Avatar
just another truck
What wire shorted? The large one, or other?
Old Mar 25, 2010 | 04:54 PM
just another truck
Sorry, I just went through everything I have here at home, and I dont have the starter wiring.. sorry..
Old Mar 25, 2010 | 04:55 PM
zanks's Avatar
zanks
the large one broke loose at the starter
Old Mar 25, 2010 | 04:57 PM
just another truck
Can you check the voltage at teh battery, both sitting and then while trying to start?
guitarpicr's Avatar
guitarpicr
Could u have run down the batteries? Can u check voltage of batt. output?
Old Mar 25, 2010 | 06:39 PM
SpringerPop's Avatar
SpringerPop
You broke the red wire at the lower left of this diagram?
http://www.e-toolbox.com/ads/wiring/va131441.pdf
That's hooked directly to the battery, and it most likely caused smoke, as it had to be drawing LOTS of current!
Check the state of battery charge first, and charge them if necessary.
The wiring diagram should help you figure this one out.
Pop
Old Mar 25, 2010 | 07:17 PM
zanks's Avatar
zanks
i'll charge them up in the morning and post results. Right now when i turn the key on everything turns on then the instrument panel just goes crazy and i can here the glowplug relay steady clicking.
Old Mar 25, 2010 | 07:45 PM
just another truck
I am really leaning towards dead battery.. Looking forward to hearing from you in the morning!!
Old Mar 25, 2010 | 11:07 PM
twags6's Avatar
twags6
The clicking usually happens with low or dead batteries. If you had that wire fall off and ground out you really sucked down those batteries. Hopefully it didn't kill them completely. Was anything on the batteries or the cables running to them melted? I'd take a look at the ground wires too. There are two large ones that bolt to the engine itself. One runs down from the drivers side and the other comes from the passenger side.
Old Mar 26, 2010 | 07:44 AM
zanks's Avatar
zanks
I'm waiting on my boss to take me over to get the batteries checked. I'm working out of town so living in a hotel broke down is not good. Anyone know a good mechanic in Madison, In....lol
Old Mar 26, 2010 | 08:35 AM
SpringerPop
Until you get those batteries charged back up, we don't know that you even need a mechanic. Hang in there for that, first.
Pop
Old Mar 28, 2010 | 09:20 AM
zanks's Avatar
zanks
Took the batteries to autozone and they wouldn't even take a charge of course i missed they one year warrIanty by one month, but after the prorate i got them both for 40$. I put the new batteries in and she cranked right up. I am kinda leary of the starter wire i bought it's only about half as big as the one that broke. Thanks for all they help guys
Old Mar 28, 2010 | 09:37 AM
just another truck
Contact ED for a OEM wire. The other options would be to make your own, a welding supply company, lowes, electrical house, all can help you.
Glad it worked out for you!!!
Old Mar 28, 2010 | 10:05 AM
Kwikkordead's Avatar
Kwikkordead
That's a huge connection to just break like that.
Corrosion?
Salt damage?
Have you checked and cleaned the ground cables, battery terminals?
pancake
Electrical Systems/Wiring
Feb 19, 2017 12:57 PM
codyjames990
Dec 7, 2016 08:52 PM
codyjames990
Dec 7, 2016 04:46 PM
FL SuperDuty
Aug 8, 2015 04:14 PM
82 F150
Jul 19, 2013 08:03 AM
