New Here, Problem with a missfire.
Old Mar 25, 2010 | 11:12 AM
Catmastermike's Avatar
Catmastermike
I have a 2000 Ford Expedition with a 5.4l 150,000miles
I brought it to the shop with a hard missfire and the need for a new right headgasket.
The hard missfire would come and go. It would only miss when the throttle was applied.
I paid $1400 for a New Gaskets, Labor, used coil pack and new injector.
The oil leak is fixed, the hard missfire is fixed.
Now it misses and idles really low when I am not on the throttle. Typically between 500-800 RPM, anything over that and it is completely smooth. No check engine light.
I brought it to the shop that did the work and they said there is nothing wrong with it. They said they reset the cam sensors and cleaned the MAF, but the problem is still there.
What is desired IDLE RPM on a engine at operating temp?
Any thought on my missfire at Idle?
Old Mar 26, 2010 | 06:30 AM
torkum's Avatar
torkum
Could be a low grade misfire thats not setting a code. Since the COP is used might want to consider a new Motorcraft.
Skippersauto
Oct 9, 2016 01:34 PM
carter g
20
Jul 29, 2016 06:46 AM
bdent11
1997 - 2003 F150
18
Jul 25, 2016 08:32 AM
ClatonK
2004 - 2008 F150
May 31, 2011 10:22 PM
twinturbopantera
4 Cylinder Engines
16
Feb 22, 2005 04:51 PM
