Sponsored by: Real Truck
2006 F250 5.4 engine problem
Old Oct 9, 2016 | 10:46 AM
Skippersauto's Avatar
Skippersauto
Ok I rebuilt the engine in my f250 5.4 3v. Timing set cam phasers and oil comtrol valves are new. Problem im having that just started after 5k miles on new engine is all of a sudden i will start getting misfires 1st time it happened said #6 i changed coil same problem came back this time said multiple misfires now im just getting #4. When the misfires happen if i hold throttle where it is it will missfire as long as i hold it there if I let of gas then apply right back missfires stop for several miles then will happen again. I have changed fuel pump and fuel pump driver module same problem exist. Any ideas please
Old Oct 9, 2016 | 12:01 PM
seville009's Avatar
seville009
Had to change all of the spark plugs in my 2006 F350 5.4l before it ran smooth again. Been fine since.
Old Oct 9, 2016 | 12:33 PM
Skippersauto
Were u having same symptoms
Old Oct 9, 2016 | 01:34 PM
seville009's Avatar
seville009
Yes - didn't happen all the time, but enough to be worrisome. I'd be pulling out onto a main road, for example, give it the gas and it would start coughing and bucking - had to let up on the gas to let it work. In the meantime, traffic was flying towards me.....not fun.
I also switched to ethanol free gas.
Tim Vo
Dec 17, 2016 06:19 AM
bma2001
Jul 22, 2016 04:01 AM
mark_5102
2004 - 2008 F150
Feb 18, 2015 06:35 PM
bigern6697
2004 - 2008 F150
Nov 26, 2012 11:35 AM
250 deathwobble
Feb 23, 2012 07:27 AM
