1994 white smoke
Old Mar 25, 2010 | 12:34 AM
F-250 MT's Avatar
F-250 MT
1994 white smoke
My '94 powerstroke bellows white smoke when i start it up. After it's warm it still smokes but just a little bit. But when i get it up to about 2000 rpm it stumbles and smokes. I was thinking i might have some bad injectors, but i heard it could be my o-rings, is there any way to tell without pulling my injectors?
Old Mar 25, 2010 | 07:36 AM
Neal 97 250's Avatar
Neal 97 250
White smoke at startup is sometimes normal in cold temps but if it does it alot or when it is warm that is a sign of glow plugs or relay. The stumbling is a whole different issue. It could be that you do actually need o-rings. Do you have any oil in the fuel filter or is the filter and fuel in the bowl dark? Is there fuel in the oil?
Is the smoke still white once the truck is warm?
Old Mar 25, 2010 | 11:55 AM
JamesHajek's Avatar
JamesHajek
First off, welcome to FTE, I am thinking that is injector o rings, I have heard if you put your truck in neutral and then rev it, if it stumbles in that middle rpm range than your o rings are going.
Old Mar 25, 2010 | 01:27 PM
F-250 MT's Avatar
F-250 MT
Alright i'll start with o-rings, we'll see how it goes
Old Mar 25, 2010 | 01:48 PM
JamesHajek's Avatar
JamesHajek
Riffraff has orings for cheap. like 60 bucks or something.
Old Mar 25, 2010 | 01:55 PM
Krisx125's Avatar
Krisx125
Related to this thread!! Why doesnt my f-350 take throttle when cold? But all my other diesels do?
Old Mar 25, 2010 | 01:56 PM
JamesHajek's Avatar
JamesHajek
Could be the ebpv. does it change when you punch the throttle?
Old Mar 25, 2010 | 04:36 PM
Krisx125's Avatar
Krisx125
EPBV is unplugged.
VQT
Nov 20, 2013 10:18 PM
Regulator1988
Jan 8, 2013 05:30 PM
JaySVX
Mar 29, 2011 08:48 PM
whitesdford
Jul 14, 2010 02:13 PM
