not a mech.
Old Mar 24, 2010 | 04:05 PM
Stapuph's Avatar
Stapuph
not a mech.
have haynes manual but need to locate temp sensor on 300/straight 6. need diagrams on on same
Old Mar 24, 2010 | 04:48 PM
5.0Torx's Avatar
5.0Torx
Be ready for some sore abs! Its under the #6 exhaust primary tube.
Old Mar 24, 2010 | 05:39 PM
fordman1090's Avatar
fordman1090
It depends on which sensor. The gauge sensor is under the #6 exhaust manifold like said above. The computer temp sender is on the thermostat housing next to the heater hose and upper radiator hose.
Old Mar 24, 2010 | 05:41 PM
fordman1090
Also, if its the one under the exhaust make sure the engine is cool, otherwise boiling coolant drains all over you.
Old Mar 24, 2010 | 05:44 PM
AbandonedBronco's Avatar
AbandonedBronco
What year engine do you have? If it's an older carb engine, there'll only be the one on in the back, under the #6 exhaust port.
