Will 250 - 300 engine mounts interchange?
Old Mar 24, 2010 | 05:06 AM
jem44357's Avatar
jem44357
Is the block 3 bolt pattern the same? Do the blocks share any common dimensions like overall length? Or the distance from the engine mount to the bellhousing mounting surface or to the front water pump mounting surface?
Jim
Old Mar 24, 2010 | 10:37 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
240 or 250ci? Big difference. 240 is a big block, 250 is a small block.
Old Mar 24, 2010 | 11:29 PM
jem44357's Avatar
jem44357
250. I know the 200/250 are the same base and the 240/300 are the same. I wonder if their are any common dimensions between the 2 sets. Will they share engine mounts can I swap transmissions? Just another one of my wild azz ideas.
Jim
havi
20
Nov 29, 2011 03:01 PM
jim collins
Nov 8, 2010 01:40 PM
jim6liter
May 22, 2008 09:48 AM
Jims55F100
Feb 13, 2007 08:04 AM
