normal boost pressure
Old Mar 24, 2010 | 01:39 AM
562dragnhra's Avatar
562dragnhra
i have a 6.9 diesel with an Allison AT545 4 speed auto, and i put a Banks Sidewinder turbo on it, my question is that i dnt get no turbo boost until i floor it, but when im just crusing at 45-55 mph, the boost gauge always reads 0, when i floor it it jumps to 7-8 psi, is that how it supose to work??? only when i floor it??
Old Mar 24, 2010 | 01:43 AM
Sycostang67's Avatar
Sycostang67
Pretty much, boost is really only generated under a load. Having an intercooler probably makes that even more noticable since it will lower your boost pressure.
How do you get away with a hood stack in california?
Old Mar 24, 2010 | 01:47 AM
starmilt's Avatar
starmilt
It will usually have a little just cruising it depends on how much power your using and how much fuel you are giveing it, most claim 3 or 4 on flat ground running fairly empty, this will vary with things like wind or any thing that takes more power to maintain speed.
Old Mar 24, 2010 | 04:07 PM
Sycostang67
With his gear ratio and tires, I'd be surprised to see any boost generated at cruising speed. When I cruise at 55-60 on flat land I'm only getting 1psi of boost. What's your rpm at 55mph?
Old Mar 24, 2010 | 04:12 PM
starmilt's Avatar
starmilt
Dayum I just looked at his gear setup,I agree 100% with you. I don't know what my IDI runs empty, I'm thinking not much (no guage) but was going by what others have posted. All my big trucks runs very little at cruising speed light throttle.
Old Mar 25, 2010 | 02:49 AM
Sycostang67
He probably gets really good highway mpg with that setup.
Old Mar 25, 2010 | 07:17 AM
fonefiddy's Avatar
fonefiddy
Sounds like a boost leak to Me. The common culprits are the intake hat hold down bolt and the intake hat/intake seal.
You should see a coupla lbs at cruise. My Sidewinder shows 5 psi @ 1400 RPM cruise.
nicksorenson
Jul 30, 2014 07:57 AM
dent wiz eric
Nov 25, 2010 09:27 PM
PSDiesel911
Jun 7, 2008 12:51 PM
ALPINE8181
Apr 2, 2008 06:36 AM
