302 timing
Old Mar 23, 2010 | 11:22 PM
texaskid22's Avatar
texaskid22
302 timing
This is what my alldata at work is showing, anyone have any other advice?
Old Mar 23, 2010 | 11:23 PM
texaskid22's Avatar
texaskid22
(This is a diagram from a 1983 150)
Old Mar 23, 2010 | 11:27 PM
texaskid22's Avatar
texaskid22
TIMING ADJUSTMENT
Place transmission in Neutral or Park with A/C Heater in off position.
Plug vacuum hoses from the distributor vacuum advance connection at the distributor.
Connect an inductive timing light.
Connect a tachometer.
If equipped with a barometric pressures switch (ignition module 12A243), disconnect it from the ignition module and place a jumper wire across the pins at the ignition module connector (yellow and black wires).
Start engine and allow to reach operating temperature.
With engine at timing rpm, check or adjust initial timing to specification. See: Specifications
Unplug and reconnect vacuum hoses. Remove any jumpers from ignition module connector and reconnect.
Old Mar 23, 2010 | 11:30 PM
texaskid22's Avatar
texaskid22
Old Jul 26, 2010 | 08:40 PM
WoodHeat's Avatar
WoodHeat
Hey texaskid...this is a really helpful post, thanks!
If you are needing to set it to 8° BTDC that would mean the marker would need to be on the 8° mark to the RIGHT of TC. Is that correct?
Old Jul 26, 2010 | 08:43 PM
ctubutis's Avatar
ctubutis
Yes, that's correct, assuming you are standing in front of it and looking at it from that
vantage point.
Old Jul 26, 2010 | 08:45 PM
WoodHeat's Avatar
WoodHeat
Thanks ctubutis!
propellerhead
15
Apr 25, 2017 12:28 PM
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
DaXman
Jul 3, 2015 05:38 PM
