1978 - 1996 Big Bronco
Radio Amp Location
Old Jan 25, 2003 | 03:18 PM
speed1972's Avatar
speed1972
Radio Amp Location
Does anyone know where the amp is located. I've got a 93 and I want to swap radios but I have to find the amp first..... TIA for the info..... Larry
Old Jan 25, 2003 | 03:56 PM
ecarter50's Avatar
ecarter50
Radio Amp Location
If it is the same as a F150 above the gas pedal and to the right.
Old Jan 25, 2003 | 04:24 PM
steve83's Avatar
steve83
Radio Amp Location
carter's right. It's mounted parallel to the firewall and pretty hard to get to. You can probably find diagrams here.
Old Jan 26, 2003 | 11:08 AM
BOJOFASO's Avatar
BOJOFASO
Radio Amp Location
i didnt know that there was a seperate amp. is this the case with a 1991 also or is my amp bult into the radio?
Old Jan 26, 2003 | 11:29 AM
ecarter50's Avatar
ecarter50
Radio Amp Location
The separate amp is only used with AM/FM/CD player.
Old Jan 27, 2003 | 08:13 AM
steve83's Avatar
steve83
Radio Amp Location
Look in these pics for a couple of shots of the radio & amp.
Old Jan 27, 2003 | 11:06 AM
speed1972's Avatar
speed1972
Radio Amp Location
Actually, if you look at the wires that plug into the back of the Am/Fm/Cassette, you'll see that there are not enough wires to run all the speakers. One bank (plug) of wires is for power, dim switch, ground, etc. The other bank of wires is for the output to the speakers. There are only five wires output so it would be kind of hard to run 4 speakers with only 5 wires.....gotta have 8. I just put one in my mustang which by the way, had an amp connected to the factory am/fm/cassette and it was set up the same way.
Old Jan 27, 2003 | 11:37 AM
steve83's Avatar
steve83
Radio Amp Location
5 wires is plenty to run 4 speakers. They share a ground.
Old Jan 27, 2003 | 05:26 PM
Redness's Avatar
Redness
Radio Amp Location
You probably don't need to access the factory amp just use a wiring harness from radio shack and be sure not to connect the blue amp turn on wire because it will not work if you do
Old Jan 27, 2003 | 06:35 PM
steve83's Avatar
steve83
Radio Amp Location
Yes, you have to get the connector off the amp to connect any aftermarket pigtail. The one at the CD player isn't connected to the truck or speakers directly, so you can't tie into it without using the factory amp.
Old Jan 27, 2003 | 09:33 PM
speed1972's Avatar
speed1972
Radio Amp Location
so I'm supposed to run all 4 grounds to that single one?.... doesn't make sense. i've never heard of that... i'm sure it can't be good for the head unit
Old Jan 28, 2003 | 07:21 PM
steve83's Avatar
steve83
Radio Amp Location
Read the instructions with your new head unit. If it says you need independent grounds, then you'll have to run new speaker wires or at least cut the factory ones after they split behind that connector.
lg405
Nov 2, 2007 03:55 PM
wheelhorse2
Bronco II
Mar 4, 2005 09:54 PM
mantta
Electrical Systems/Wiring
Nov 11, 2004 03:04 PM
mantta
Nov 11, 2004 03:02 PM
dakota larry
Jul 5, 2004 09:54 AM
