What else do I need??????
Old Mar 22, 2010 | 12:54 PM
1_BIGMOFO's Avatar
1_BIGMOFO
I am doing the complete EGR Delete and Oil Cooler rebuild and here is what I got so far:
First Coast performance FULL EGR Delete with new intake
New oil cooler
Dieselsite coolant filtration system
2 ball valves for the filtration system
extra filter
RMI-25 coolant system treatment
Rotella T oil
Motorcraft Oil filter
Things I am getting at the dealer tomorrow:
4 gallons of Motorcraft Gold anti freeze
VC9 treatment (iron cleaner used to flush the cooling system)
gray Permagasket (dealer only???)
Also Getting:
18 gallons of distilled water from the local grocery store.
Do I need any gaskets? (im pretty sure Cheezit said the intake gasket was reusable but are there any other gaskets)
Screen under the cooler (part number???) (is it called a HPOP screen???)
What else do i need? (Im going and I dont want to leave anything out)
Thanks for the help,
Rob
Old Mar 22, 2010 | 01:04 PM
1_BIGMOFO's Avatar
1_BIGMOFO
How about a thermostat??
Is it something I should get at the dealer or will an Advance Auto Parts one do the trick??
Old Mar 22, 2010 | 01:40 PM
rickatic's Avatar
rickatic
New oil cooler
extra filter
Rotella T oil
4 gallons of anti freeze (whats the name of it at the dealer?)Motorcraft Gold
VC9 treatment (can I get this at the dealer?)(iron cleaner used to flush the cooling system)Only available at Dealer
Also Getting:
Screen under the cooler (part number???)(HPOP screen???)Replace it $15
Rob
I have not seen many guys, actually none, that changed the thermostat. I did not. The intake gaskets are reusable as long as you are careful not to damage them. You will understand when you see them. Oil cooler rebuild kit includes all the seals and gaskets. You may need a dab or two of the overpriced gray Permagasket. I got lucky, My tech buddy had a tube. I do not recall what year your truck is. If it is an 05 or newer, I would replace the STC fitting on the HPOP pump. Around $45 but you are 90% there when you have it torn down this far. Be meticulous in your cleaning of the oil sump under the oil cooler. This is where the HPOP screen lives. Any thing that gets past the screen goes through the HPOP pump. Bad thing.
Good Luck
Old Mar 22, 2010 | 01:47 PM
1_BIGMOFO's Avatar
1_BIGMOFO
my trucks an 04 so I got lucky there Sweet, thanks for the heads up!!
Old Mar 22, 2010 | 02:51 PM
bismic's Avatar
bismic
I would upgrade the turbo oil drain also ..... and throw in the BB mod on the fuel pressure regulator just because!
Old Mar 22, 2010 | 04:34 PM
1_BIGMOFO's Avatar
1_BIGMOFO
Can you explain a little more? Whats a BB mod??
Old Mar 22, 2010 | 05:11 PM
rocky1074's Avatar
rocky1074
This Post is from another member, I copied it for you
This is how i performed the bb mod on my truck. This mod is to boost fuel pressure up from 55 to about 75. First i removed thermostat housing by removing using a 10 mm. I then pushed the thermostat housing to the front to give me room to remove fuel pressure regulator. Then remove the line on the fpr. The bolts on the fpr are a t27 torx. Remove all four bolts holding it to the upper fuel filter. Watch out because the spring has it under pressure. Make sure the spring and brass poppet valve doesnt fall out. Take a .177 bb and slide it in the brass poppet and reassemble everything. You will lose some coolant doing this mod so make sure you have some on hand. Some companies sell a longer spring but the bb is cheaper
Old Mar 22, 2010 | 05:17 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Turbo oil drain? Part number, and this must be for our 04's?
was there also a turbo kit of some sort?
I'm making my list for this job also.
Old Mar 22, 2010 | 05:20 PM
rocky1074's Avatar
rocky1074
Turbo Oil Drain Tube (Larger) 6C3Z-9T515-A
Ford Turbo Kit 4C4Z-9V424-AA
Old Mar 22, 2010 | 05:35 PM
1_BIGMOFO's Avatar
1_BIGMOFO
Thanks man
the list is rough!! I cant wait to just get this all done and over with!!!
These are ford part numbers? How much is this stuff?? Do you need to upgrade anything else at the same time? Do the new parts come with any dangers or anything I should know??
Old Mar 22, 2010 | 05:37 PM
amdriven2liv
Rocky, Thank you!
Old Mar 22, 2010 | 05:51 PM
1_BIGMOFO's Avatar
1_BIGMOFO
is there a site to see how mch they cost?
Old Mar 22, 2010 | 05:55 PM
rocky1074's Avatar
rocky1074
I purchase most of my parts at:
http://www.trademotion.com/partlocat...?siteid=215005
The Turbo kit gives you everything you to recondition your turbo: Diesel Technician Society
Turbo Oil Drain Tube (Larger) 6C3Z-9T515-A 21.83
Ford Turbo Kit 4C4Z-9V424-AA 60.64
I don't know of any dangers. Just take your time, do it right and once. You have to lift the turbo to change out the oil drain tube, Might as well pull it off and recondition it.
Old Mar 22, 2010 | 06:01 PM
1_BIGMOFO's Avatar
1_BIGMOFO
you can recondition your whole turbo for $60.00?? Thats crazy!! How long does it take to do both?
Thanks for the great tips man!!
Old Mar 22, 2010 | 06:53 PM
rocky1074's Avatar
rocky1074
I didn't need my truck being I have another vehicle.. I stretched it out over 3 days. Day 1 took if off ; day 2 recondition turbo ; Day 3 Put back on ...I am not a mechanic it did take me a good part of the day to remove it. putting it back in a 3-4 hours of hours. If you need info on removing the turbo let me know. I have a good write up THANKS to other member's of FTE.
THEY GOT ME THROUGH IT!!!!
