Programming new keys
Old Apr 25, 2002 | 12:06 PM
dvanhorn's Avatar
dvanhorn
I have a 98, with only one key. I've got a key blank with transponder.
I have a procedure to add a third key, but I only have one key, and want to add a second.
Is it more or less the same thing?
Does someone have the exact procedure?
Old Apr 25, 2002 | 06:31 PM
Johnny Mo's Avatar
Johnny Mo
I think with the 98 you only need 1 original/master key to program a new one. On the 02 you need both original/master keys to program a new blank.
Old Apr 25, 2002 | 10:21 PM
nitro94's Avatar
nitro94
I have been told that it requires 2 previously programed keys to program a third with the instructions found in the owners manual. Otherwise the dealer has to erase and reprogram at least 2 new keys using special equipment.
Old Apr 26, 2002 | 08:25 AM
Big's Avatar
Big
My wife drives the 1997 Expy we have. We needed to make another key for it shortly after we bought it (used). The procedure was spelled out in the manual. I can't reference it now as my wife has the truck. As memory serves, it is something like this:
insert original key
turn key to on (do not start)
turn key to off
remove original key
insert new spare key
turn to on (don't start)
theft light should flash, then go out (I think it will do this)
turn spare key to off
remove.
done.
Look in your manual for something like this. The dealer told my wife that he didn't think I could not do this. Go ahead and try but I think you will be back. I told her no way. I know I read it in the manual that I can program the key (not the key fob). So I did it.
If I think about it I will look it up and repost the directions.
I do know this - you can only attempt to program keys a set number of times - like 25 or fewer. Check it out.
Good luck
Big
2000 F250 SD SC 5.4L Gasser 4.10s 4x4 L/S rearend Western 7'6" plow (hate it-have to have it)White with parchment cloth
Old Apr 26, 2002 | 01:32 PM
adelyser's Avatar
adelyser
Big's got it right. For the '97 and '98 models, you only need one original key to program another. for the '99 to current models, you need 2 original keys to program a third. Also, for the '97 and '98 models, you can freshly program a key if you have no other key for it, but it's a timely procedure.
Old Apr 26, 2002 | 01:37 PM
adelyser's Avatar
adelyser
toys4dlr
Sep 21, 2024 06:44 AM
CMOS
Jan 25, 2010 02:16 PM
jas88
1997 - 2003 F150
24
Jun 22, 2009 03:01 PM
-Jim G
Dec 6, 2008 01:09 PM
bodabdan
1983 - 2012 Ranger & B-Series
Apr 2, 2006 07:07 PM
