7.3l died while driving
Old Mar 3, 2014 | 03:36 PM
  #31
Wiredoge4's Avatar
Wiredoge4
The IPR is connected toward the bottom of the HPOP. Look at the fuel bowl on the drive side of the fuel bowl (low) you should see a wiring that is going to the bottom of the HPOP. You will also see that there is a small tin nut after that plug. Disconnect the plug and take the tin nut off. After that you will need a 1 1/8 deep socket to take the IPR out. once out make sure you have something to plug the hole or oil will drain out. Let me know if you need any more help.
Old Mar 3, 2014 | 09:27 PM
  #32
kev03's Avatar
kev03
thank you for the info.
Doc Wright
Sep 22, 2016 11:00 AM
rlansdon
31
Apr 20, 2016 07:55 AM
barkmulcher
23
Sep 2, 2011 01:14 PM
fixnair
Jul 4, 2010 12:19 AM
RichPSD
15
Dec 23, 2005 07:32 PM
