thinking about buying
Old Mar 24, 2010 | 09:08 PM
UNTAMND's Avatar
UNTAMND
Originally Posted by Big Ruth
460 is a good mill but it was a passenger car engine designed during the oil crisis. A stock 460 was lucky to see 250HP.
Not knocking the 460 as its a solid motor but it the 7.3 is a commercial motor that has seen its ways into 60,000GVW applications.
Well.....sorta
the 460 was built back in the late 60s. You could get a 360hp 490tq 460 in the big lincolns. Not sure what the 460 specs were for the mid 70s trucks, but the cars were from 220-270hp I believe.
Not really oil crisis numbers, but I know what you mean. Also, there were a lot of 429 and 370 (same block as the 460) being used in commercial and industrial applications. Lots of school busses and f600-f700 trucks had them. I have an f800 4x4 marmen herrington conversion truck that has the 429 4v, and a school bus with a 370, and an f850 crane truck with a 429 4v engine.
Old Mar 25, 2010 | 07:22 AM
Big Ruth's Avatar
Big Ruth
Originally Posted by UNTAMND
Well.....sorta
now that you mention it, I can remember riding on school buses way back in the day and them being gas motors. I imagine some of them did have the big ford gasser in it.
Old Mar 25, 2010 | 12:35 PM
brian42's Avatar
brian42
Veteran: Navy
I will admit my 7.3 isn't breaking any speed records.
I didn't buy my 7700lb truck with all the aerodynamic styling to be the first anywhere.
The 7.3L is an undeniable dog when compared performance-wise to the other diesels out there. But at 196K miles, I would not hesitate to go outside, start it up and drive it across the country right now with nothing more than a gallon of oil in the bed to top it off every few days.
Old Mar 25, 2010 | 12:45 PM
UNTAMND's Avatar
UNTAMND
the 7.3L is an undeniable dog when compared performance-wise to the other diesels out there. But at 196K miles, I would not hesitate to go outside, start it up and drive it across the country right now with nothing more than a gallon of oil in the bed to top it off every few days.
My gasser was first all the time......it was to the gas pumps but hey, gotta be good at something.
My 8000+ pound land rocket is a real weapon now that I have the 120hp tune for it. I dont use it much, but its fun.
My truck 7.3 has 229628 miles on it, and Ill crank it 9 hours to Philidelphia here next month, AND BACK, and ill add less then a drop of oil to it. Its amazing really. My 95 460 truck, has 255xxx on the clock with the original engine, and if it could take a sticker again (rust issue) id crank that ol bugger there....if there were plenty of money in the bank that is; Oh, and Ill need more then a gallon of oil for that one.
Old Mar 25, 2010 | 01:54 PM
Fishin76's Avatar
Fishin76
I've now driven about 2K miles in a couple months with my 2000 7.3, and it has not used a drop of oil. 236K on the clock.
Old Mar 25, 2010 | 02:26 PM
brian42's Avatar
brian42
Veteran: Navy
Mine does good now that I've fixed my oil leak.
If I'm running loaded it'll burn some, but I don't add more than a couple of quarts between changes. It's more than none, but at almost 200K I'm happy with 1/2 gallon makeup rate.
Old Mar 25, 2010 | 03:13 PM
Izzy351's Avatar
Izzy351
Dog, huh.... Bring it on!!
