U-joint sizes
79 Bronco, with 78 D60s. My rear drive shaft has the u-joints for the 9inch, which are too big for the D60 yoke. Do I need the yoke from the 9inch (if it will fit) Or do they make a joint to fit both? The width seams OK, just the cap diameter. I would assume the front is going to be the same way,,,,,,I have the drive shaft from the 78 F250, but hate to have it cut and fitted to the Bronco's shaft,,,,,,
They make conversion joints.. you have to find a guy that's willing to take a few minutes to look it up for you though. My driveshaft guy is the mang, which is why I never wrote down or can remember the part # for the joint you're looking for
I might be able to take a look at it for you and find some #'s on it though if you can't find it.
U JOINT INFO
Series Joint Width Cap Diameter Max angle Continuous Ft Lbs Short Duration Ft Lbs
1310 3.219" 1.062" 30* 130 800
1330 3.625" 1.062" 20* 150 890
1350 3.625" 1.188" 20* 210 1240
1410 4.188" 1.188" 37* 250 1500
here you go.
here you go.
Tyler S
58
Feb 9, 2014 07:21 AM
