Found the Chicken
Old Mar 21, 2010 | 08:00 AM
Jim Allen's Avatar
Jim Allen
Found the Chicken
Got my 6.9L out and apart and discovered the source of my problem.
The head gasket blew out violently on #7 at about 8-o'clock on the cylinder to the lower water jacket. It must have happened suddenly while I was cruising at 65, overpressurized the cooling system and blew out that freeze plug at the back of the block. Looking closely at the area where the gasket blew, it doesn't look like there was any signs of long term prior leakage.
I guess I get to go the ARP head stud route now, check everything over well and fix anything marginal. I'll likely replace all the rockers with the 7.3L type, reseal the engine top to bottom, get the injectors and pump tested. I think I'll get the turbo rebuilt as I noted a lot of slop in the shaft.
Engine is very clean inside!
Kinda dodged a bullet.
Old Mar 21, 2010 | 03:14 PM
Sycostang67's Avatar
Sycostang67
Thats good, but where was the chicken? I had a bird in my stacks, but a chicken wouldn't fit.
Old Mar 21, 2010 | 03:29 PM
David85's Avatar
David85
Pictures would be nice but still, very good news!
There was some one on OBN that had a similar instant gasket failure. He was worried that something major had come loose inside because it had a knock. In the end he decided to do a complete rebuild anyway since he had the engine out. Last I heard he was tearing a layer off the roads somewhere in Nebraska.... His 1986 now has a moose pump, turbo, intercooler and 5 speed.
Old Mar 21, 2010 | 09:53 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Another 6.9 lives for another couple of decades.
Glad everything was better than you were expecting Jim.
Just remember, torque the ARP's down and remove them 4 times before the final install.
You are going to have a sore arm the day after you do the head stud install.
Old Mar 22, 2010 | 10:08 AM
Jim Allen's Avatar
Jim Allen
I'll get around to pics.
I strongly doubt I'll do a full rebuild... mostly because it doesn't remotely need one. I'll freshen up anything that looks marginal but the truck now gets so few miles per year that it's got decades left in it even without a full overhaul or rebuild.
Where does everyone like to get their 6.9L engine parts? I'm definitely doing the rockers, so a full set is on my list.
RustyTrustyF150
Sep 30, 2013 12:30 PM
99f350sd
Aerostar
19
Jan 15, 2010 09:51 PM
fkhcle
Apr 13, 2009 06:34 AM
Frisco the Dog
Feb 16, 2008 09:30 PM
jroehl
Apr 13, 2004 10:18 AM
