Iowa Chapter Join Chapter, Leader:
Spring chat thread
Old May 19, 2010 | 12:06 PM
  #391
fellro86's Avatar
fellro86
It is definitely a nice one today... I finally got the right belt for the mower, third try on that... the other was so shredded it was difficult to get the right length from it...
Found a ZF 5 speed that will work in my 86, thinking strongly of getting it. Still need to get a flywheel and clutch assembly, but that is only about $400 usually for the Luk solid conversion.... the trans is only $100 here locally... downside is that I just put a new clutch in it about a year ago... no longer would be useful with the conversion.
Old May 19, 2010 | 12:25 PM
  #392
67nukeford's Avatar
67nukeford
Veteran: Navy
I wish I could adapt a 5 speed for my 67 onto the 390. I know they make adapter plates, but I'm told they cause problems with the clutch and input shaft.
Old May 19, 2010 | 12:32 PM
  #393
fellro86's Avatar
fellro86
I'm sure you would need to also have some kind of spacer to move the flywheel back, which then probably wouldn't support the front of the input right... hmmm...
Old May 19, 2010 | 12:56 PM
  #394
67nukeford's Avatar
67nukeford
Veteran: Navy
Yep. And that's part of the problem. So, I'm going to try and find a T-18 or -19, I think. Unless I scrap the FE idea, and go with a 351.
Old May 19, 2010 | 01:00 PM
  #395
fellro86's Avatar
fellro86
Well, I would be pulling a T19... however, it is 4x4. Until my dad gives up on the 2wd, I can't get rid of that one. Now if I were to not rebuild the 77, there would be a 435 or whatever those transmissions are... You could always try to pick up an add on overdrive unit. The Gear Vendors unit that I took out of the Dodge donor for the 92 is divorced, made for a lot easier install.
Old May 19, 2010 | 01:32 PM
  #396
67nukeford's Avatar
67nukeford
Veteran: Navy
Mine is a 4x4 Roger. Is that the tranny with the granny low gear? I'm wanting whichever one doesn't have that.
Old May 19, 2010 | 01:43 PM
  #397
fellro86's Avatar
fellro86
It has granny, but synchronized. Not sure what truck trans doesn't have granny short of the 3 speed overdrive trans...
Old May 19, 2010 | 01:46 PM
  #398
67nukeford's Avatar
67nukeford
Veteran: Navy
do you have a transfer case with it?
Old May 19, 2010 | 02:14 PM
  #399
fellro86's Avatar
fellro86
I do have that case, but would likely keep it in the truck. Also have a whole other truck I can take it from as well. Just a matter of parting with it, but then, I haven't wiped out any t-cases as yet over all the years I have drive, short of the 203 in the old 75, but 4.10 up front and 3.73 in the rear can do that...
Old May 19, 2010 | 02:30 PM
  #400
67nukeford's Avatar
67nukeford
Veteran: Navy
I have the single speed transfer case for mine now, but I'd like to get the 2 speed case for it. I have the NP 435 tranny also.
Old May 19, 2010 | 03:50 PM
  #401
fellro86's Avatar
fellro86
I have the parts truck, I think they use the BW1345 or some such as that, but they are hi/lo transfer cases. It is a diesel 4 speed as well.
Old May 20, 2010 | 07:22 AM
  #402
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Good Morning Iowa!
Roger any news yet on the school front?
Old May 20, 2010 | 08:13 AM
  #403
67nukeford's Avatar
67nukeford
Veteran: Navy
Good morning Steve, Roger, and the Iowa gang! Wet day here in eastern Nebraska.
Old May 20, 2010 | 08:15 AM
  #404
fellro86's Avatar
fellro86
No news as yet, they move a bit slow...
Old May 20, 2010 | 08:18 AM
  #405
67nukeford's Avatar
67nukeford
Veteran: Navy
What's the difference between the diesel and the gas ones?
