The guy i bought my truck from said that the passanger rear door will not latch shut if it is opened from the inside so it has been on child lock for the past 7 years
I went and checked and it still does the same thing now
Does anyone know what causes this?
Oh, I typed before I understood. It will open, but not close after. That sounds like a broken spring in the latch, or the inside handle not returning. Anyhoe you still need to remove pannel.
oh
well the door will close just if you open the door from the inside it will hang up and not latch when closed so you have to open it from the outside
Does it work if you lock the door before you close? Sometimes I have to do that do get it to shut. All started after I replaced my door lock actuators..
i dont know i could try that in the morning. If it isnt working though I can get to unhang by pulling the outside door handle and then closing the door.
