Drivers power window
Old Mar 20, 2010 | 06:43 PM
Xerophobic's Avatar
Xerophobic
Yet another thread asking about the good ole drivers power window motor.
Mine stopped working in a very slightly down position(so I guess it could have been worse!) and wouldnt go up. I could hear a clicking in the fuse box area when trying to go up. It would go down however. I took the door skin off(I praise the person who designed that little gem that doesnt break $40 worth of clips and such like most door skins) and removed just the motor. After disconnecting it from the regulator(if you doing this be prepared for the tension of the big spring!) I tried the motor again, sure enough worked fine in one direction only. Dissasembled the motor and cleaned the armature etc, reassembled, still nothing.
I purchased what I was told was a good used unit and I still have the identical problem. Is there something else in this system which can go bad?? The relay appears to be the same as the one above it and they both act exactly the same when installed in the power window position(click when trying to go up).
Idea's????
Old Mar 20, 2010 | 07:06 PM
jh818's Avatar
jh818
Is it possible that you have dirty contacts on your switch?
I had that happen on my power seats and I cleaned them off. Now it works great.
Old Mar 20, 2010 | 07:59 PM
EXv10's Avatar
EXv10
Water gets in on most cars' switches from rain and the washer, ruining that switch.
Old Mar 21, 2010 | 04:40 AM
05ExcursionatorCA's Avatar
05ExcursionatorCA
mine makes a rattling sound when going up, anything to fix it?
Old Mar 21, 2010 | 01:49 PM
EXv10's Avatar
EXv10
Try taking panel off and spray silicone all around possible squeak areas.
Old Mar 21, 2010 | 11:27 PM
05ExcursionatorCA
I will try doing this, and post results. Thanks.
poppop50
Jan 7, 2021 09:14 PM
Aztrainer
1997 - 2003 F150
15
Mar 16, 2020 11:14 PM
kyledallas
19
Jan 3, 2012 04:42 PM
1997 F-150
South Carolina Chapter
Oct 1, 2010 06:52 PM
mikren
1997 - 2003 F150
28
Aug 22, 2009 09:39 AM
