Sponsored by: Real Truck
Brake pressure switch leaking
Old Mar 20, 2010 | 05:42 PM
ReAX's Avatar
ReAX
I finally got time to swap out the brake pressure switch because the cruise control has been deactivated for a while. I got the switched unplugged and brake fluid started dripping out. I checked the fuse and it was saturated with fluid. How is that better than when the switch itself gets wet? The fluid will still bridge the contacts. In any case, Ed got me a switch and I'm good again.
Old Mar 20, 2010 | 11:35 PM
wallz's Avatar
wallz
Has your been previously replaced? There is a recall out on this.
Old Mar 21, 2010 | 04:45 AM
redford's Avatar
redford
FTE Leadership Emeritus
Well, that could explain why they were recalled for causing fires.
Old Mar 21, 2010 | 07:17 AM
ReAX's Avatar
ReAX
I had the fuse harness put in under the recall a couple weeks after they included the superduty. I was disappointed at the time because it seemed like a band aid rather than a fix. I can't see the fuse helping the situation, the switch was cheap enough I wish they had done it right the first time.
Are these new switches "leak proof"?
Old Mar 21, 2010 | 07:27 AM
projectSHO89's Avatar
projectSHO89
The new switches are "better". Nothing is "leakproof".
The fused harness was just so that your truck wouldn't burn up when the switch eventually failed.
Old Mar 21, 2010 | 07:36 AM
ReAX's Avatar
ReAX
That's why I used the quotes. Even submarines leak.
My thought though is what is the difference between brake fluid saturating the connector and shorting out vs brake fluid saturating both the fuse holder and the connector and shorting? A short is a short, next to the M/C or in the middle of the harness, correct?
Old Apr 20, 2010 | 04:47 PM
wog's Avatar
wog
I'm in same situation, cruise just stopped working and I found the recall harness was saturated with brake fluid, so cruise unit is getting a +12v on its brake pressure input regardless of whether I have the harness connected to the leaking sensor or not. ..apparently brake fluid is conductive.
Question, ...was it a big hassle to bleed the system after replacing the switch??? Thanks.
Old Apr 20, 2010 | 05:14 PM
ReAX's Avatar
ReAX
I went under the theory of if the fluid could flow out freely, then air could not climb back up. So I pulled the cap on the MC and then unscrewed the sensor and put the new one in as quickly as possible. The idea is if atmosphere can push down on the reservoir then air will have no need in traveling up the MC.
Old Apr 21, 2010 | 09:56 AM
wog's Avatar
wog
Thanks, will give it a shot tonight. I picked up the switch from Ford last night, $22 and it included the fused harness extention (good thing since my current one is saturated with leaked brake fluid).
...Is there any thread sealant required on the new switch to prevent leaking? Did you use anything?
Thanks.
Old Apr 21, 2010 | 10:16 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I changed the sensor out in '07 because it was leaking. The dealer said it was not on recall at the time. I paid 27.00 for the sensor and pigtail. Has not leaked again and I didn't put anything on the threads.
Old Apr 21, 2010 | 04:48 PM
ReAX's Avatar
ReAX
My switch was pre-lock-tite'd, it had some kind of hard red sealer already applied. It's a two pole plug and uses power, so it shouldn't need a ground. Not needing a ground, a thread sealer shouldn't effect it's operation.
ttoptom1
1997 - 2003 F150
Jul 24, 2016 05:37 AM
Shane Carruth
May 7, 2016 06:19 AM
Gotanoldtruck
Oct 2, 2015 08:42 AM
themansfield
Apr 30, 2012 07:55 AM
spongecop
Feb 23, 2012 09:24 PM
