lift kit
Old Mar 20, 2010 | 04:13 PM
ohmar99's Avatar
ohmar99
lift kit
whats the cheapest way to raise my 94 up about 2 inches
Old Mar 20, 2010 | 05:43 PM
mabc926's Avatar
mabc926
Lift blocks.
Skyjacker Lift Block Kits at StylinTrucks.com
Old Mar 20, 2010 | 06:23 PM
starmilt's Avatar
starmilt
If it is a f350 springs on the front, if it has the ttb front there is no cheap way.
Old Mar 21, 2010 | 01:41 AM
idahodisco's Avatar
idahodisco
I am going to have my springs rebent + add a leaf the guy I talked to got a extra 4" on his and it only cost him $350. looked good
Old Mar 21, 2010 | 02:19 AM
93_F250's Avatar
93_F250
Saw this suspension kit online for a 4WD
They also have low cost 2" Body Kit for the 2WD
Old Mar 21, 2010 | 02:02 PM
ohmar99's Avatar
ohmar99
the springs on the front of mine look like they are bent backwards, Its not so easy on bumps
Old Mar 21, 2010 | 02:15 PM
RCrawler's Avatar
RCrawler
Must be an F250. They have a negative arch spring.
There are a couple of things you might look at. First, check the front spring shackles where they mount in the frame. It is pretty common for the bushings to get beat out of them, causing the front end to sag. It will also make for a harsh ride when there is no cushion there and the bumpstops are closer to the frame.
Jason
Old Mar 21, 2010 | 02:25 PM
ohmar99's Avatar
ohmar99
yep F250 4X4 thanks
Old Mar 21, 2010 | 06:58 PM
dyoung14's Avatar
dyoung14
ADD A LEAF then a good front end alignment
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
