Which flywheel do I need?
Old Mar 20, 2010 | 10:28 AM
ksteen's Avatar
ksteen
I just bought a 300 inline six that had been hooked up to a manual transmission. I have now bought a C-4 transmission and was needing to know which flywheel I need to buy to fit it? Could someone please help me out with this. Thanks.
Old Mar 20, 2010 | 01:51 PM
BarnieTrk's Avatar
BarnieTrk
It's my understanding that a flywheel is used with the manual transmission, whereas a flexplate is used with an automatic transmission.
So, if I'm understanding you correctly, you're looking for a FLEXPLATE (and required spacer ring) that will allow you to properly bolt up your 300" straight 6-cylinder engine and will engage with your C-4 automatic transmission, correct? I will assume you've confirmed that the C4 transmission has the correct bellhousing bolt pattern to bolt up to your 300" 6-cylinder. I'm not an expert, but I do know some C4's came with different bellhousing bolt patterns.
I'm not positive, but if I recall correctly, the 240" 6-cyl and the 300" 6-cyl engines use a starter ring gear that is the same diameter and tooth count.
So, I think you're looking for a flexplate from a '64-'72(+?) 240" or 300" E100, F100 or F250 that had a C4 automatic transmission.
I don't know what the correct starter ring diameter size or tooth count is though...... -- sorry.
BarnieTrk
Old Mar 20, 2010 | 02:09 PM
312's Avatar
312
flywheel
bernie is right a 240 or 300 will be needed.you will also need to change the end of your starter.dont use a v8 flywheel they will fit but out of balance.
Old Mar 20, 2010 | 02:19 PM
BarnieTrk's Avatar
BarnieTrk
Yep, 312 is correct... the cone section of the starter is a different length for an automatic versus a manual....
Might just be easier to exchange/replace the entire starter, unless you have access to both...if so, then you could switch the cone sections. If you do want to switch cone sections, make sure the armature bushing is in good shape and a smear of a greasy finger inside it would be a good thing....
BarnieTrk
Old Mar 21, 2010 | 09:48 AM
theejohnnyb's Avatar
theejohnnyb
Will the pilot bushing hang up the converter?
Old Mar 21, 2010 | 10:50 AM
Bill W's Avatar
Bill W
No, the converter bolts to the flexplate.
Old Mar 21, 2010 | 04:16 PM
garbz2's Avatar
garbz2
The pilot bushing needs to be removed so the crank can accept the pilot on the converter. The converter is machined to fit in to the bare crank.
All fords nomenclature for flywheels include standard and automatic. All the service manuals refer to flywheel and do not call out a flex plate. .
In GM terms it differs flex plate for a auto, flywheel for a manual.
Garbz
Old Mar 21, 2010 | 06:28 PM
Bill W's Avatar
Bill W
I did not know that! as yall can tell.... thanks for correcting me.
Old Mar 22, 2010 | 06:44 AM
BarnieTrk's Avatar
BarnieTrk
-- Garbz
Interesting.... I didn't know that either.
Thanks for setting me straight as well, Garbz!
BarnieTrk
Old Mar 22, 2010 | 02:21 PM
ksteen's Avatar
ksteen
Barnie,
Please excuse my ignorance but when you mention spacer ring, where does it go? Does it go between the flexplate and the crank?
Old Mar 22, 2010 | 10:52 PM
garbz2's Avatar
garbz2
Its one of those things like stepside or high boy....
The spacer ring is in increments to shim the flywheel typically .010, .015, and so on it is to set the teeth in relation to the starter. Some times it is necessary some times it is not.
FEs also use a ring on the side facing the clutch as a reinforcement for the flywheel in an automatic application. That one is about .060. or a 1/16 inch.
Garbz
firemanmarc
Apr 21, 2016 07:56 PM
ezsqueez
Dec 4, 2015 06:04 PM
BushyTea
Jan 25, 2015 07:14 PM
squarethumps
WTB - Parts & other
Oct 14, 2013 11:14 AM
jimpennycuff
Jun 15, 2007 10:49 AM
