Sneak Peek Project Update
A couple sneak peek pics
https://www.ford-trucks.com/forums/7...66-f100-6.html
Man thats a BAD A$$ truck, I really like the ( T oil pan ) nice touch !
Looks like the booster and valve cover may be a problem at some point ? Some have used the
smaller booster with the big block install ! What are you doing for Taction?
P.S. Thanks for the pics , please keep them coming , LOVE IT !!!!!!!!!!!!!!
Wally Womack
All 65-67's (FE) should have the cast p/s brkt. My 65 with Factory P/S has it too. Pretty sure its a t-bird casting number but will double check.
Wally Womack
I bought a NOS 66 Booster but did not have the correct brkt so decided to go with the 77 Booster which I already had and just rebuilt it. Should the need arise in the future for replacement the 77 is much easier and less $$ to come by.
I assume you meant traction? I plan on putting 325/50 Nitto's on the back and not sure of the front yet. Plan was using the custom made wheels to fit NOS Stock hubcaps but the front dropped beams are wider than stock so have a wheel issue right now.
In the rear I am running the stock 3.50 gears but added a Yukon Posi (the HP version)
Trans is a Cobra Jet C-6 From a 1969 428 Mach 1, plan on going with a custom made driveshaft.
Pic of trans before my re-do.
Block is a Side Oiler, heads are CNC'd Edelbrocks, Intake is Factory Ford Issue Tunnel Wedge MR, Carbs are custom Quick Fuel 750's.
I removed the Edelbrock script from heads and water pump so it appears a bit more stock like a vintage 427 of this year would have.
here is a wheel pic with NOS hubcap. Trim ring will most likely not be used but have them just in case. Wheels will be painted body color to match or possible powdercoated if I can get close enough in color. License plate is also neat as is Solid Copper a very rare plate.
He had a lot of pull when he wanted something. Case in point the Arizona trucks were supposed to come out of California but Sam knew the Texas plant manager well enough to get what should have been special orders on a normal order.
Same place did the wonderful powdercoating on chassis, rear axle, cross members and front suspension components. They even plated the spindles silver cad.
I sandblasted the frame and components before bringing them down to the plater/powdercoater
I'm sure he will thank you later. Good luck remembering where all those bolts go! haha.
