Weird Transmission thing
Old Mar 18, 2010 | 09:52 PM
OutlawNomad's Avatar
OutlawNomad
Has this ever happened to any of you?
I was parked "Looking for my door code under the dash" and when I went to leave I put the Ex in reverse & it didn't move.
I gave it some gas & it still didn't move. I put it back in to park and then reverse and gave it more gas, the truck seemed to "unfreeze" and flew into reverse.
Old Mar 19, 2010 | 12:13 AM
jh818's Avatar
jh818
Check your ATF level.
Old Mar 19, 2010 | 09:14 AM
njstevens's Avatar
njstevens
do you have play in your shifter. It is possible you are not lining up right.
Old Mar 19, 2010 | 09:37 AM
OutlawNomad
I did, everything looks good there. I'm having it changed Monday
Old Mar 19, 2010 | 09:38 AM
OutlawNomad
I thought that too but the truck was almost "frozen" like the emergency brake was on & then suddenly released.
Old Mar 19, 2010 | 10:29 AM
njstevens's Avatar
njstevens
so you could feel it was engaged just something holding back like you are sitting at the start oof the 1/4 mile race?
Old Mar 19, 2010 | 11:26 AM
OutlawNomad
Yep, like I had line locks on...
Old Mar 19, 2010 | 08:09 PM
jh818's Avatar
jh818
Does it drive ok in D? Have you had your diff. oil changed?
Maybe your calipers are siezed?
Old Mar 20, 2010 | 05:33 AM
brian Felts's Avatar
brian Felts
Sounds like a caliper to me?
B
Old Mar 25, 2010 | 10:57 AM
njstevens's Avatar
njstevens
any update on this issue yet. Like to know solutions when they happen in case i run into it
Old Mar 25, 2010 | 11:09 AM
OutlawNomad
Hey Nj,
No update as of yet but then it has not happened again either. I can olny assume that one of the calipers were frozen open and then retracted when I moved.
dbeers02
Missouri Chapter
Mar 15, 2014 01:44 AM
andrewscofield
15
Feb 1, 2014 10:54 AM
Ryan'sF250
Mar 29, 2012 09:50 AM
TYZ78F150
Oct 30, 2010 07:17 PM
bawrestler
May 3, 2007 06:55 PM
