Sponsored by: Auxito
skipping
Old Mar 18, 2010 | 04:45 PM
FordDavid's Avatar
FordDavid
skipping
My 2002 Ford F-150 cranks and idles fine and usually runs good when the motor is cold, but after it warms up it begins to skip while driving. Although under heavy acceleration it doesn’t seem to skip. Any suggestions?
Old Mar 18, 2010 | 04:46 PM
FordDavid's Avatar
FordDavid
Old Mar 18, 2010 | 06:53 PM
darkmage55's Avatar
darkmage55
Maybe you have a little leak in the heater hoses above number 3 and 4 plugs? Check those hoses and see if they are leaking at all.
Old Mar 29, 2010 | 12:53 PM
FordDavid's Avatar
FordDavid
Nope no leak
Old Mar 29, 2010 | 12:58 PM
93 mix 'n match's Avatar
93 mix 'n match
any codes? probably a bad coil...
Old Mar 29, 2010 | 06:03 PM
FordDavid's Avatar
FordDavid
yes I a bad gas code and the I got O2 sensor then I got mass air flow??????
t1956bird
15
May 23, 2019 08:02 PM
Tugly
45
Dec 12, 2012 07:20 AM
fordmaniac21
Jan 2, 2003 07:10 PM
DrFord
Nov 21, 2001 03:18 PM
fatforty
Feb 15, 2001 10:37 PM
