How to attach plate to frame?
I have a 2000 F-350 Cab/Chassis and I want to bolt down a 1/2" thick steel plate and attach my 5th wheel setup to the plate. There are no holes in the top of the frame rails but there are tons of pre-punched holes on the sides of the frame. My question is can I use J bolts or something similar to attach my plate to without having to drill new holes in the frame rails? Any suggestions are appreciated.
Thanks... I found out they don't make a bracket for the Cab/Chassis Setups. It was suggested to me to mount 3x4x1/2" angle iron to the outside of the frame rails and attach the mounting rails to that. My question now is what precautions should I take when drilling into the frame (other that hitting important lines, etc.) Is it safe to drive the sides of the frame rail? I no drilling into the top flange of the rail is a no-no but are the side ok to drill into? Any thoughts are appreciated. Thanks.
>ule of thumb I go by is don't weld the sides, and don't drill the top or bottom. but then again that was with heat treated frames of semi's.
Yes, I was taught that too.
Is there any way you can have someone weld 3/8 side plates to the 1/2" base plate and attach to the side of the frame rails that way?
duallycrew
05-22-2014 09:19 PM
Corpsman24
08-13-2013 05:08 PM
NWO_diesel_nut
04-19-2012 10:36 AM
