starter issues
Old 06-10-2013, 03:40 PM
needhelp49's Avatar
needhelp49
needhelp49 is offline
starter issues
i put a flat-o-matic behind my 239 and that works great but my starter stays a little engaged. I've tried just about everything i can think of even got the newer style bendex but it wont even fit in there. At this point i really don't have 200 bucks for a new starter. anyone got a fix?
Old 06-10-2013, 06:20 PM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Did you try to shim it?
Old 06-10-2013, 06:24 PM
needhelp49's Avatar
needhelp49
thought about it except the flathead starter pulls the drive into the flexplate not push so if i shim it will move the gear closer to flex plate not further
Old 06-10-2013, 06:33 PM
The Horvaths
Is the starter shaft parallel to the crank? If it's just binding, shimming one side could allow it to clear. If it's truly too short, then the starter gear/shaft is just built bad from the start, no? Maybe an expert will chime in.
Old 06-10-2013, 09:06 PM
festus555's Avatar
festus555
festus555 is offline
The flat o matic install instructions mention the starter issue. Flat-o Products, Inc.
Old 06-10-2013, 10:19 PM
The Horvaths
That's pretty clear. Thanks for chiming in.
Old 06-10-2013, 11:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Easy solution (no pulling the engine or trans) -- buy a gear-reduction starter. They hit the ring gear from the front, and never hang up.
Old 06-11-2013, 06:32 AM
bk53's Avatar
bk53
bk53 is offline
step 4 in the instructions mentions this possibility right, not saying this is your issue.
Old 06-11-2013, 08:04 AM
needhelp49's Avatar
needhelp49
thanks guys it looks like it's between the new kitchen faucet or a starter im voting on the starter but not really sure i get a vote in these things
Old 06-11-2013, 11:49 AM
festus555's Avatar
festus555
Just wondering if you could slide the drive a little on the starter shaft to take care of it ? That is if it is the clearance issue.
I don't have one to look at but maybe swap a spacer or even machine the gear some? All depends on how much it's hanging.
I'm cheap!!
Old 06-13-2013, 10:14 PM
needhelp49's Avatar
needhelp49
i'm the cheapest but after fighting this thing for 2 years i broke down a bought a mini starter should be here tomarrow
SteevenH
1997 - 2003 F150
08-12-2011 04:56 AM
tbart16
08-19-2009 09:03 AM
elrod2020
09-12-2007 08:24 AM
64STYLE
07-12-2007 09:37 PM
jhuffer
08-09-2003 02:01 PM
Quick Reply: starter issues
