Offroad & 4x4
Extend Vent Hoses???
Old Jan 23, 2003 | 10:17 PM
bronco351's Avatar
bronco351
Lightbulb Extend Vent Hoses???
Hi, guys I have a 1990 Ford Bronco with a 6" lift. I notice that the vent hoses for my front and rear axles don't extend that high up at all. My question is is it ok to extend those hoses up into the engine compartment so they don't suck in water when mud bogging. Also extend the rear axle vent hose higher up under the body.
I would really appreciate any help from anyone whose done this, Also where would you get the hoses from?
THANKS A BUNCH!!!!!
Old Jan 24, 2003 | 02:26 AM
LW555's Avatar
LW555
definitely a good idea. i just used regular vacuum line and replaced the entire short original ones with really long ones. the vacuum line seemed stiff enough so it wouldn't kink around corners. make sure to leave slack in the hose for axle drop, and at the end put a small inline filter to keep out bugs and dirt. also it's good to point the opening down to keep out dripping water.
Old Jan 24, 2003 | 02:33 AM
pbrstreetg's Avatar
pbrstreetg
Hi-
Get the hoses from Discount or anywhere. Use rubber 5/16 or 3/8, vacuum or fuel line, doesnt' really matter. Use worm type hose clamps so they stay there if they lightly get snagged. Don't forget the transfer case and the transmission. If you get under there you'll find them. Put them at least as high as your air intake setup. A lawn mower fuel filter works nice on the ends, but arguably not neccessary.
Old Jan 24, 2003 | 07:43 AM
AlM's Avatar
AlM
yo,
Here is Brian's tech site on vent ext.:
http://soderblom.net/bronco/tech/vents/
Old Jan 24, 2003 | 12:20 PM
rebocardo's Avatar
rebocardo
Make sure your brake line hoses (front and rear) have enough slack as well as the vent tube hoses.
On my trucks, I like to run the vent hose up to the rear cross member, position it on the back so it points down in a U shape. Sticking a vent on is great as long as you maintain it.
If you do a lot of mud, you might be better venting it into the tailgate. Been a while since i owned a full sized Bronco, but, you should be able to run a vent into the bottom of the tailgate on the driver's side.
Old Jan 24, 2003 | 08:16 PM
nolanc2's Avatar
nolanc2
Since your axel moves and whatever you tie your vent hose to doesn’t especially with the extra articulation the lift adds you can use some of that coil hose for an air compressor. I’ve only seen it in yellow but if it matches your truck it looks pretty cool and wroks well.
rogerranger2122
1983 - 2012 Ranger & B-Series
Oct 3, 2016 09:22 PM
Crimson
1997 - 2003 F150
Jul 17, 2016 09:27 AM
dustyroad
Sep 2, 2015 08:02 PM
mah678
Nov 23, 2005 01:45 PM
bronco351
1978 - 1996 Big Bronco
Mar 8, 2003 08:11 AM
