Fuel vent hose question
Old Sep 1, 2015 | 09:04 PM
dustyroad's Avatar
dustyroad
https://www.ford-trucks.com/forums/9...vent-hose.html
Originally Posted by dynamic
You need to tape the fill hose and the vent hose together in order to allow the tank to vent while filling. If your vent hose is sitting lower than the fill hose the tank will not let the fuel vapor escape from the tank thus not allowing you to fill your tank.
We run into this issue alot in the body upfitter world. Lots of customers bring the trucks back to us with fill issues after they do a home install or a retrofit or it was too close to quiting time in the shop! When you start running 2-3 foot fuel fills you really have to make sure the vent hose is above the fill hose!
I am replacing my tank, found a cheap used/new one.
My old one, was emissions but nothing was hooked up.
The new one is non-emission but I didn't think it would be an issue.
Well I missed the part about the filler/vent hose orientation.
The tank holes are flipped to each other.
example
O o =new tank
o O = old tank
No biggy I think, I'll just get a bigger vent hose and cross it over the filler hose and clamp it down.
Now I wonder if this is even possible without having venting issues.
Has anyone done this successfully or did you just replace the filler neck hardware to match?
Old Sep 2, 2015 | 02:18 AM
burnthelight88's Avatar
burnthelight88
I haven't done this, but I don't see why you'd have venting issues as long as no hoses are kinked.
Old Sep 2, 2015 | 09:12 AM
dustyroad's Avatar
dustyroad
I agree seems like a silly question but it would suck to have to take it apart because gas keeps puking out at me.
Old Sep 2, 2015 | 09:26 AM
GLR's Avatar
GLR
A friend with a 78 got a 79 tank. Put a 79 filler neck on it. I've got a 78 tank (new, cheap)to put in my 79 so I'll use a 78 filler neck, and hole saw a hole for the emissions vent.
Old Sep 2, 2015 | 08:02 PM
dustyroad's Avatar
dustyroad
Yea I probably would have tried to grab up everything when I picked the tank up if I paid attention to the hose orientation.
I'll look for a filler neck, hope it's cheaper than the hose.
Grampa jepp
Mar 2, 2019 04:04 AM
dmtcpa
Jun 26, 2014 02:41 PM
mejonz
Oct 14, 2011 11:30 PM
ghunt
Nov 24, 2009 03:00 PM
barbsbuddy
Feb 21, 2009 08:56 AM
