My *%&@#$& Trailing Arms
#61
#62
#63
#64
Well I finally got into it yesterday. did the passenger side, but had to wait until today to finish as I had to go buy a come along. That did the trick. Mine are about .5 inches longer than the one I took off, measured center to center.
My question is, can I wait a few days to do the other side? I mean is it okay to drive it even though one arm is slightly longer? I would prefer to wait until better weather, but I don't want to chance it hurting some other part, axle, pinion, etc
Anyone have some advice? thanks
#65
#67
#69
#70
If you're responding to me there, I've got an '01 which, to my knowledge, has never had them replaced... And I haven't bothered to look at them because I didn't know it was a possible issue.
#71
Ok so you know how it happened. I was going down I 70 in Pa when both trailing arms broke and the flange yoke broke. I had it towed to my house where I did replace the trailing arms with exact fit ones, I got a great deal seeing I know an auto parts owner. I am still waiting for the new flange yoke and 2 u joints, I figure it's out so I might as well replace both at same time. I was going about 55 miles an hour when I hit a pot hole I didn't see then I heard dragging, the drive shaft then fell out and rolled to the side of the road once I stopped. I had the drive shaft checked for balance it's still good. I will get the flange yoke in the morning and will then put all that back together, I wasn't able to mark the shaft to the rear axle seeing it fell out. That's when I saw the track bar it's still good but will need replaced.
#72
davewild
349
08-30-2020 10:17 AM
kythri
1997-2006 Expedition & Navigator
01-13-2018 12:20 PM
2civicrr
6.7L Power Stroke Diesel
05-22-2017 05:48 PM
