Rear Lower Trailing Arm Removal - Driver Side - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-06-2018, 06:00 PM
kythri's Avatar
kythri kythri is offline
kythri is starting off with a positive reputation.
Vehicle: 2000 Expedition Eddie Bauer.
So, I was having some issues with the upper trailing arms (solved here: https://www.ford-trucks.com/forums/1...m-removal.html), but now I've ran into an issue with the lower arms, specifically, the driver's side.
Passenger side swapped out no issues. The driver side, however, the frame-to-arm bolt won't come out - it backs up against the fuel tank, and there's no slack to remove it. It was already a giant pain to break the bolt/nut loose given that a ratchet or breaker head wouldn't fit on the bolt head in the first place - had to brace a wrench with a breaker and wedge it in there to be able to bust the nut loose.
Is there a trick to this that I'm missing? I'm really hoping that the solution isn't to drop the fuel tank.
Old 01-06-2018, 09:37 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
Originally Posted by kythri View Post
Is there a trick to this that I'm missing"? I'm really hoping that the solution isn't to drop the fuel tank.
Cut the head of the bolt off with a cut off tool.
Install new bolt.
Old 01-07-2018, 09:57 AM
alloro alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
Quote:
Install new bolt.
Lots of posts regarding this and everyone just cuts the head off and installs a new bolt in the opposite direction. BTW, a sawzall with a new 24tpi metal blade works too. Only other option is to drop the fuel tank. The bolt is a grade 10.5 so don't just use any new bolt in there.
Old 01-07-2018, 10:30 AM
kythri's Avatar
When torquing it back down after replacement, are you torquing from the bolt head, instead of the nut?
Old 01-07-2018, 04:42 PM
Yes, not much choice unless like I said you want to drop the fuel tank.
Old 01-13-2018, 01:20 PM
kythri's Avatar
Thank you!
Rear Upper Trailing Arm Removal kythri 1997-2006 Expedition & Navigator 2 01-05-2018 09:07 PM
Gear Box & Hose Replacement for Dummies sammie0126 Excursion - King of SUVs 101 06-12-2017 04:07 PM
Lessons learned leveling my 2015.....hope this helps others. 2civicrr 6.7L Power Stroke Diesel 4 05-22-2017 06:48 PM
2005 F150 lower control arm bolts seabeeman 2004 - 2008 F150 5 11-21-2016 02:38 PM
My *%&@#$& Trailing Arms alloro 1997-2006 Expedition & Navigator 71 05-27-2016 01:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
