Quick IP Adjustment Question
Old Mar 17, 2010 | 07:37 PM
93_F250's Avatar
93_F250
From everything I've learned and been told on the forum, I needed to "turn a few flats" on my IP to increase power (EGT's = 300*-550* max uphill) and my near zero boost issue.
Well - I searched this forum and read up on the subject and yesterday I removed the cover, hand cranked the engine until I saw the allen head screw (first time was not that easy) and was able to turn about 1 flat. Went for a climb (about 85* out) with no real noticeable difference.
After work today - I went to adjust it again and the screw will not move.
So my question - does adjusting the screw clockwise (as you look at the screw thru the access panel) increase fuel? Did I go the wrong way (I hope) or am I maxed out and this is a sign that my pump is going bad?
Thanks in advance...
Old Mar 18, 2010 | 01:00 AM
starmilt's Avatar
starmilt
IIRC clockwise increases and you don't want to max it out.
Old Mar 18, 2010 | 01:54 AM
Sycostang67's Avatar
Sycostang67
Yes, turning the screw in clockwise increases the fuel. How old is your pump? I have heard several people mention that with old/worn pumps, they had the screw maxxed out and couldn't get any smoke. I'm not saying you want a ton of smoke, but obviously if the screw is maxxed and you get no smoke, something is wrong.
Old Mar 18, 2010 | 02:49 AM
93_F250's Avatar
93_F250
It's the factory pump with 110K miles. I'll play with it tomorrow after work to see if it's maxed or jammed or something else. Perhaps I need to check fuel pressure?
If it is bad - is there a bitchin' aftermarket IP? Should I do larger injectors at the sametime? Would it make a big performance difference or should I just replace the IP with OEM replacement and clean and test my injectors? Can you get remanufactured pumps? Sorry - lots of questions.
I'm actually trying to get more boost. A little smoke would be OK if it gave me more charge-air and kick.
Luckily I have a car and two motorcycles to get me around - but I only live two miles from work...I should be on the bicycle.
Old Mar 18, 2010 | 11:39 AM
Sycostang67
I'm getting my stuff from the guys on oilburners. I'm ordering some new "bb" code injectors from russ(Typ4) this week and when the time comes, I'll be sending my IP to Mel(Agnem) for a baby moose rebuild.
Old Mar 18, 2010 | 11:36 PM
93_F250's Avatar
93_F250
Got home today and tried again - no more clockwise flats left. I can adjust counter-clockwise - but why?
Guess I'm just maxed out and will look into a Moose or Dps injector pump I read starmilt mention on another thread..
Old Mar 19, 2010 | 12:43 PM
axe_handle's Avatar
axe_handle
I'm not sure what the emissions testing is like for you, but you may want to consider that when you replace your pump with something hotter. In the Seattle, WA area I have to get an emission check every 2 years. I have my max fuel screw, and fuel rate curves set on the aggressive side and I blow a fair bit of smoke with any sort of load, and make good boost and power doing it.
I installed a Hypermax Smoke Puff Limiter to keep my EGT down when lugging up hills in low boost situations.
I had my emissions test last week and I was really nervous going into it. I figured failure was a certainty. Apparently the Hypermax SPL works because I tested at 8% opacity, well below the 40% limit here.
I only say this, because Hypermax recommends tuning your pump on a flow bench when you install the SPL. I couldn't do that, but if you are having the thing rebuilt, it might be something to think about.
1989f250IDI
Jul 26, 2012 09:53 PM
eatont9999
Aug 4, 2011 04:51 PM
mike112898
31
Jun 13, 2011 12:18 AM
therifleman556
Mar 22, 2011 11:10 PM
tinsleystyle
Jan 14, 2009 04:18 PM
