460 cam
Old Jan 23, 2003 | 09:37 PM
nolanc2's Avatar
nolanc2
460 cam
I just installed a Summit Racing cam in my 460the cam has a 204/214 duration @ .05 479/504 lift and 112 deg lobe separation the timing set is a new OE replacement. Is it normal to have to run timing at 25 deg BTDC, that is wear it seems to run the best.
Old Jan 24, 2003 | 06:13 AM
DeenHylton's Avatar
DeenHylton
460 cam
It your running 25 BTDC at idle...that would not be normal. If that is the case you probably have the dissy in one tooth off. At idle you should have the vacuum advance disconnected and plugged to check initial timing. Deen
Old Jan 24, 2003 | 03:51 PM
nolanc2's Avatar
nolanc2
460 cam
I did disconnect the VA but I didn't plug it. I will tri that as soon as I get home. I was very careful to have the timing marks on the new gears aligned just right.
Since this isn't normal how can this be corrected and could it be doing any damage, it has very good throttle response and a little more power and it's not overheating at all.
Thanks for the help.
Old Jan 24, 2003 | 10:23 PM
grclark351's Avatar
grclark351
460 cam
is it possible your balancer is "spun"? did it time differently before the work you did on it? you may want to verify TDC on your balancer using a piston stop tool. call back if not familiar with this.
Old Jan 25, 2003 | 08:39 PM
nolanc2's Avatar
nolanc2
460 cam
The balancer does look a little ragged some of the rubber is coming out from between it but it was running a perfect 8-10 BTDC before the cam installation.
I don’t have a piston stop tool and I've never used one.
If the balancer is spun wouldn't the timing mark on the balancer change a little every time I revved the engine hard, I've only cheeked it twice and never got on it between checks this could be happening if so would a balancer from a 460 in a 70's Thunder Bird work I have one that looks to be in good shape. I don’t know the real difference between internally and externally balanced other than exactly how it sounds but my truck motor I think is external and the car motor is internal I say this because the truck motor has that spacer with the balancing lobe on the side of it behind the balancer and the car motor doesn’t.
Old Jan 28, 2003 | 12:22 AM
Superdave's Avatar
Superdave
460 cam
Yes your truck motor is externally balanced. 79 and up 460's are the way you mention.
I have been told there is no difference in the balancers themselves.
I cannot verify this fact at all.
I would say to thoroughly check out the older balancer for a visual match.
You can buy a new one also.
Old Jan 28, 2003 | 12:33 AM
Superdave's Avatar
Superdave
460 cam
RebusCom
Dec 6, 2014 07:40 PM
RebusCom
Dec 6, 2014 06:24 AM
zrxlover
Aug 5, 2009 08:36 PM
bigal72
Jul 28, 2002 04:50 PM
