cam timing vs vacuum
I have an '89 E-350 with FI 460. The engine was recently replaced with stock remanufactured but compared to the old engine (which had some badly burned valves) power is significantly less and gas mileage dropped from an average of 12mpg to only 6mpg highway with the same driver and general (easy) driving conditions.
It starts and runs okay but I'm suspecting the cam is retarded. I put a manifold vacuum gauge on it and with idle ignition timing at 30deg. the idle vacuum sits at 16" Hg. Anyone with 460 experience care to speculate?
As far as I know the timing sets are interchangeable and they could have also got it off a tooth.
Base ignition timing without SPOUT is 12deg. Retarded ignition timing can contribute to lower vacuum but that is not the case here. It runs at stock 30deg. at idle with SPOUT. 16" Hg seems lower than it should be but I thought I'd check with others.
Riderman
34
01-11-2010 11:01 AM
1977_250_460_C6
01-04-2005 01:01 PM
rmcgraw351
09-09-2004 12:48 PM
