My truck is a 76 f100 I6 2wd, so I am on my way to work, I stop at a light and hear somthing rattlen under the hood. Once at work I check it out, the pully and the attached fan has a slight wobbel. Shut it down and I am able to jiggle the the pully/fan up and down, side to side. I still have to get home about 15 miles, freeway, How is the pully/fan connected and in your guys opinion from the info given, how safe is it to drive home? All feed back is appreciated.
Sounds like the water pump is going (gone) out. You might be able to make it 15 miles, but remember it will go out at the worst possible place. Is it leaking yet?
