motor is running backwards
Old Mar 16, 2010 | 05:25 PM
phelpsville's Avatar
phelpsville
Unhappy motor is running backwards
Ok, I have an 88 ford f150 and the wipers park vertically! when I turn them on, they come down to where there supposed to park then go back up (to park) I just got the truck from a good friend of mine and he replaced the wiper motor. just wonder if he did something wrong backwards!
thank you.
Andrew.
Old Mar 16, 2010 | 05:26 PM
zxwut?'s Avatar
zxwut?
Check all the wiring and make sure it was installed correctly.
Old Mar 16, 2010 | 05:33 PM
phelpsville
all the wiring is correct, (at least into there perspective harnesses)
Old Mar 16, 2010 | 05:35 PM
zxwut?'s Avatar
zxwut?
Is everything physically back into the correct spots?
Old Mar 16, 2010 | 05:36 PM
phelpsville
yes all the wires are back in the correct spots.
Old Mar 16, 2010 | 05:38 PM
phelpsville
the motor is like backwards... i cant figure it out!
Old Mar 16, 2010 | 05:42 PM
Hitokori's Avatar
Hitokori
change the hot wire and ground wire around
its a d/c motor so reversing them will change the direction it rotates
Old Mar 16, 2010 | 05:44 PM
phelpsville
they would be the top wire? (red) and bottom wire (black) what of the middle wire?
Old Mar 16, 2010 | 05:47 PM
Hitokori's Avatar
Hitokori
leave it thats the delay that comes from the switch
Old Mar 16, 2010 | 05:54 PM
phelpsville
ok, I am going to try it....wish me luck!
Old Mar 16, 2010 | 05:56 PM
rla2005's Avatar
rla2005
thank you.
Andrew.
There is your problem in bold. The bell crank is off by 180 degrees. Been there, done that and I still have the scars on my hands to prove it. The wiper drive motor only turns one direction. It's the bell crank that makes the wipers sweep back and forth.
I have seen more than a few replacement wiper motors come out of the box not in the PARK position. This usually results in the bell crank being installed 180 degrees out of position. The wipers will stop/park at the top of the arc, not the bottom.
Old Mar 16, 2010 | 06:06 PM
zxwut?'s Avatar
zxwut?
Don't change my wires. Check this ^^^
phoneman91
64
Feb 2, 2025 05:40 PM
OlBrownTruck
Apr 27, 2017 04:02 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Apr 26, 2016 05:50 AM
michaelshewkin
Jan 13, 2014 09:03 PM
myonlytruck05
Jan 12, 2012 05:11 PM
