NOW WHAT DO I DO???
Old Mar 16, 2010 | 05:15 PM
82airborne82's Avatar
82airborne82
NOW WHAT DO I DO???
ok so I got a 77 f250 with the original 460 motor and it runs awesome! no leaks or knocks or anything its got at least 200k miles. I changed the oil the other day and i put Mobile 1 full synthetic blend thinking this would be good for the old truck, now theres a oil leak! its small but Im worried about it so does anybody know where to start checking seals and what ones to check? im seriously starting to regret putting the synthetic blend in the motor ran fine before also do I have a big job on my hands now? thank you for any help/suggestions.
Old Mar 16, 2010 | 05:19 PM
61 uni's Avatar
61 uni
I'd change the oil again back to what you were previously running.
Old Mar 16, 2010 | 05:29 PM
Furyus1's Avatar
Furyus1
That's the thing with synthetics - if you have even the tiniest of leaks, the synthetic will find it... Synthetic oils have a "de-sludging" (cleaning) characteristic that can unseal leaks previously sealed by old oil buildup. I think it also has smaller molecules than a mineral oil does and can get into places the old oil can't...
I've seen it written in more than one place that, if you plan to run synthetic oil in an old engine, make sure all the leaks are sealed up first...
I run synthetics all the time - run it in my truck and don't have any problems - So far, all my gaskets are in good shape, though...
plumber01's Avatar
plumber01
personally I would not put the same oil back in just to stop a leak, because a leak is a leak whether it be slow or fast. it may have been leaking before but with a thicker oil just did not fall as fast.
But as far as where to check (oil pan gasket, valve covers, rear and front seals, you didn't just happen to spill some when you filled it did ya. what about the oil plug, its not cross threaded when put back in or did you leave a gasket off the nut?
Old Mar 16, 2010 | 06:28 PM
Rockstone's Avatar
Rockstone
2 places I'd check 1st. Oil plug, and the filter. My son changed the oil on my daughter's vehicle once, and the rubber gasket from the old filter stayed stuck to the block. Took awhile to figure that one out. 2 rubber gaskets are definitely not better than 1.
Old Mar 16, 2010 | 06:45 PM
82airborne82
thanks all for the help, now I wonder if I should run the synthetic for a few more days let it de-sludge the motor some and then put regular oil back in or is it true that once you use a synthetic in a motor you cant put regular back in??? The truck was sitting for months while I was deployed so Im sure all kinds of stuff settled
Old Mar 16, 2010 | 07:00 PM
Furyus1's Avatar
Furyus1
A "synthetic blend" is just regular oil mixed with synthetic... Shouldn't be a problem to switch back...
Old Mar 16, 2010 | 08:39 PM
82airborne82
I just remembered another question I had, what should the oil pressure be for this truck? after I changed the oil put new plugs and electronic ignition the oil pressure gauge shot right up to around 80psi! now it fluctuates between 60 and 80+ psi depending on how I drive?
Old Mar 16, 2010 | 09:08 PM
johnboy427's Avatar
johnboy427
That is really high for an old motor typically I have seen 50-60 driving and any where from 30-0 at idle out of my old motors. The one that idled at 0 ran great for years until I sold the truck so go figure. Rule of thumb is you need at least 10psi for ever 1000rpms.
-John
Old Mar 16, 2010 | 09:13 PM
hasteranger's Avatar
hasteranger
change it to a thicker blend. synthetic is for new engines only. My bet is your op and leak problems will go away with it.
Old Mar 16, 2010 | 09:22 PM
johnboy427's Avatar
johnboy427
If he has 80psi he doesn't need thicker oil, he is already getting about to the limit of the stock oil pump drive.
-John
Old Mar 16, 2010 | 10:41 PM
CraigOutdoors's Avatar
CraigOutdoors
Not sure about these older fords, but the cheb LS1 in the truck I just sold idled at about 50-60 and ran around 80 depending on how fast I was goin'. When oil got low, it'd spike for a bit then drop. That was the first sign. Then the truck would tell me that my oil was low. There are a few nice things about them 'putered up trucks. Older ones are more fun tho.
Old Mar 16, 2010 | 11:17 PM
460/5's Avatar
460/5
Zombie Survivalist
pressure in my 76 is around 50 psi at idle. i figure its a good thing, if nothin else its keepin the thick stuff movin and the hard stuff lubricated...
and yes, the synthetics break up the built up sludge and it can even be potentially harmful dependin on how much had built up. so i only run cheap "natural" oil in the old beasty.
Old Mar 17, 2010 | 12:03 AM
CraigOutdoors
What I've heard from more than one source is stick with what's in it. If it started syn, stay syn, cause it IS a better oil, but if you've been runnin reg for quite some time, stay reg. I wired a garage/apt for a guy who does mechanic work, and he was sayin he pulled apart a car that had been runnin syn from the get-go, and when he pulled it apart, all the parts were still shiny. None of the black/brown gunky buildup you normally see on the inside of a car with 100k+. He was a convert. I've also been told that syn doesn't have the corrosive leftovers from burning that reg has, which is the gunk and glazing that builds up on the internals.
I'm hopin' to find a block and do a ground up build up over time, and I'm planning on runnin' syn in it from the get go. I've read that since it lubes so well, it takes longer to break in the motor, cause the pistons don't form to the walls as fast as they do with reg. That's why some guys recommend running reg oil for the first 8-10k.
Old Mar 17, 2010 | 12:08 AM
Jermafenser's Avatar
Jermafenser
Folks, stop spreading myths.
You can run synthetic or dino anytime in any engine. It's just a better kind of oil. It's not magic.
