ENGINE TEMP LIGHT!? Help?
Old Mar 16, 2010 | 05:08 PM
TheBigGreenMachine's Avatar
TheBigGreenMachine
Red face ENGINE TEMP LIGHT!? Help?
Popped on after I went through some BIG puddles, like 2 feet of water at some points, replaced the sensor on the water pump. My temperature gauge has either never worked or the truck just perpetually runs insanely cold, but the engine temp. like just popped on, it flickers sometimes and after a long time of waiting it goes away when it's first started, but flickers back on after a couple minutes.
I'm guessing there's another sensor that I'm missing, any ideas?
Old Mar 16, 2010 | 05:16 PM
Action4478's Avatar
Action4478
Yes , the other one on the right side of the motor ...
Old Mar 16, 2010 | 05:23 PM
TheBigGreenMachine
Thanks, I'll check it out, maybe replace it, let me know if you got any other ideas...
Old Mar 16, 2010 | 05:58 PM
Action4478's Avatar
Action4478
If the motor doesn't get warm , may need a t stat...
Old Mar 16, 2010 | 07:09 PM
Hussler's Avatar
Hussler
Rick, this question is with all due respect, but I see it all the time.
Right side of motor is sitting in cab or standing in front of bumper looking at engine?
Old Mar 17, 2010 | 07:56 AM
Action4478's Avatar
Action4478
Right side while sitting in the cab....
Old Mar 17, 2010 | 10:00 AM
TheBigGreenMachine
Is it easily seen from the top of the engine/under the hood 'cause I can't seem to find it. I wasn't looking too hard, but is it down in there, or what. Easier access from where? And yes I realize this is a stupid, lazy question, but I don't care.
Old Mar 17, 2010 | 10:40 AM
Action4478's Avatar
Action4478
Looking at it from the front. Follow the EBPV sensor tube from the sensor toward the left . Right where The tube turns toward the rear of the engine, directly under the alternator bracket, you will see the wire below the tube. the sensor mounts horizontally ...
Old Mar 17, 2010 | 12:05 PM
TheBigGreenMachine
Much obliged.
Old Mar 18, 2010 | 05:39 AM
tjbeggs's Avatar
tjbeggs
Old Mar 18, 2010 | 06:20 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
BINGO! Tim's got the right pic.
If you've swapped a new Gauge sender and the gauge still reads low, your T-stat is shot
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Mar 18, 2010 | 08:01 AM
Action4478's Avatar
Action4478
Originally Posted by tjbeggs
I tried to take a pic yesterday . Fan & shroud in the way . That must have been when you were running without the fan...
Old Mar 18, 2010 | 05:33 PM
tjbeggs's Avatar
tjbeggs
yep no fan/shroud for that pic!
65cobra
1983 - 2012 Ranger & B-Series
30
Sep 15, 2018 11:58 PM
Krazee Matt
Jun 21, 2015 03:57 PM
1993_f350_2013
Jan 7, 2015 09:21 PM
IDIDieselJohn
Jan 8, 2014 10:58 PM
JustDriveTwo
Sep 16, 2011 10:57 PM
