Flickering Lights
Old Sep 13, 2011 | 10:57 PM
JustDriveTwo's Avatar
JustDriveTwo
Flickering Lights
I just recently purchased an '89 F350 7.3l and have done mainly day driving. But recently I discovered on some night drives my lamps begin to flicker after driving for awhile. The truck uses both headlights and the plow lights on the front mount as well when I am driving at night, at all times. The problem occurs after driving for a period of time and now seems to be getting worse. It use to take an hour before they all started to flicker on and off (all four lights) and then to a half hour and now it seems like 15-20mins. they now begin to flicker. I recently replaced the dimmer switch and connector (low beams were not working and yes, the lights still flickered before) but it never cured the flickering light issue. My only guess is the flickering is due to the heating up of the lamps too much? Guesses on how to cure this problem?
~All help is greatly appreciated! -Justin.
Old Sep 13, 2011 | 11:03 PM
jplinville's Avatar
jplinville
Do they all flicker at the same time? Sounds like you have a short in your positive line somewhere.
Old Sep 13, 2011 | 11:20 PM
JustDriveTwo
Yes, all four flicker at the same time.
Old Sep 13, 2011 | 11:37 PM
White 97 xlt's Avatar
White 97 xlt
Headlight switch getting hot,,, they have a thermal breaker inside.. Contacts get some age and don't make good contact, heat up, lights go on and off...
Cure? New headlight switch, and check the plug to the wiring harness, if it shows any wires discolored or insulation trying to melt replace it too.. NAPA has the switch and plug. Other parts stores should too.
Old Sep 13, 2011 | 11:43 PM
JustDriveTwo
Alright, sounds good. Will be making a trip to NAPA after class tomorrow and hopefully that's the cure. Thank you very much for the help!
Old Sep 16, 2011 | 10:32 PM
JustDriveTwo
Replaced the switch and connector today, the old connector was fried. Lights work fine now, thanks so much '97!
Old Sep 16, 2011 | 10:57 PM
White 97 xlt
Great!!! Glad to hear it......
Now, get those plow lights on a relay before you fry this switch and connector....
jmuenchow
Nov 11, 2015 05:38 PM
Four.on.the.floor
Apr 14, 2015 11:44 AM
1994F2507.3L
Oct 3, 2011 10:21 AM
Old Medic
15
Dec 3, 2010 12:59 PM
GregTruck
Nov 10, 2004 03:56 PM
