Buzzing noise
Old Mar 16, 2010 | 02:54 PM
redrock233's Avatar
redrock233
Buzzing noise
The blinker switch has a contious buzzing sound coming form it. Have changed it out. The only time it goes out is when i turn on the blinkers then everything works good all bulbs work. Its a 2004 F-250 4x4. Can anyone out there help with any info on this problem please.
Old Mar 16, 2010 | 03:10 PM
ehgeeray's Avatar
ehgeeray
It's probably the Flux Capacitor.... Just joking.... LOL
Are you sure the noise is coming from the switch itself and not something near by? I had a signal flasher go on the blink one time and it made a buzzing noise...
Old Mar 16, 2010 | 03:46 PM
redrock233's Avatar
redrock233
sorry it is the signal flasher. I have replaced it twice, all the signals still work.
Old Mar 16, 2010 | 04:20 PM
ehgeeray's Avatar
ehgeeray
Does the voltage spike as the signal flashes?
Old Mar 16, 2010 | 05:15 PM
redrock233's Avatar
redrock233
no it does not spike everything is normal that i can tell. I really dont want to take it to the dealer to find out what's wrong, i know it's something simple but just cant pin point it.
Old Mar 16, 2010 | 05:17 PM
utjer's Avatar
utjer
Is it doing it with the flasher pulled?
Old Mar 16, 2010 | 06:24 PM
redrock233's Avatar
redrock233
no just with it in place
Old Mar 16, 2010 | 06:32 PM
utjer's Avatar
utjer
Well that proves that it is the flasher. You said you have replaced it a couple of times. Have you tried a different manufacture?
Old Mar 16, 2010 | 06:38 PM
redrock233's Avatar
redrock233
got one from diff part stores still the same.
Old Mar 16, 2010 | 06:41 PM
utjer's Avatar
utjer
Well I am out of ideas at this time.
Old Mar 16, 2010 | 06:44 PM
ehgeeray's Avatar
ehgeeray
Are you getting it from Ford? sometimes other manufacturers list their parts was being compatible when in fact that is not the case... If you remove the flasher and it goes away it must be the flasher...
duvaller
Dec 11, 2014 08:45 PM
will32_
24
Sep 28, 2014 10:18 PM
flydaddy
Jan 24, 2014 02:37 PM
wyckedcombo17
Jul 25, 2011 01:23 PM
bow4elk
Jul 25, 2007 10:57 PM
