95 Ranger 4.0 stalling
The stall could be caued by a number of things, so we'll need some more clues to make a better guess.
Is it still stalling just when coming to a stop????
Any driveability problems????
Do you have a CEL lit????
Is this an auto tranny 4.0L????
Where is the vehicle on all past & present due scheduled maintenance items????
Have you replaced the fuel filter & or done a KOEO & KOER fuel presure & pressure leak down test test yet????
Any driveability problems???? none, great acceleration very smooth
Do you have a CEL lit???? no lights
Is this an auto tranny 4.0L???? 5 speed standard
Where is the vehicle on all past & present due scheduled maintenance items???? just had oil change and new plugs installed
Have you replaced the <nobr style="color: darkgreen; font-weight: normal; font-size: 100%; font-family: verdana,geneva,lucida,'lucida grande',arial,helvetica,sans-serif;" id="itxt_nobr_4_0">fuel
</nobr> filter & or done a KOEO & KOER fuel presure & pressure leak down test test yet???? no I somewhat assume it is not a fuel problem where it starts instantly and runs great, only symptom is when coming to a stopthanks for the follow up
Then it'll need to relearn it's new cold & warm idle strategy & it'll also begin to build new fuel trim tables.
The locks are controlled through the GEM, mounted in cabin, on the fire wall, behind the radio.
Does the vehicle have any aftermarket electronics, like an anti-theft system, ect????
Seeing as how it's a 95, maybe have a close look at All of the battery to engine & body ground points & make sure they are clean, bright & tight, as funky gound loops can cause all sorts of strange happenings.
Seeing as how things seemed to straighten out after the IAC was last messed with, why not also have another look in that area.
Seeing as how you don't have a CEL lit, to offer up some trouble shooting clues, & you know that replacing the IAC & having it seal well did fix the idle stall problem for 3 days, maybe suspect "Murpheys Law" is messing with you & the new IAC is bad????
I've seen bad new parts right out of the box!!!!
If you could come by a scantool that will read PID's, you could monitor the IAC ref voltage & it's PID signal back to the computer, when the engine wants to stall & maybe get a clue as to whats happening.
If you have a multimeter, you could back probe the IAC electrical connector, to make sure it's ref voltage is within range.
Do a forum search, or look in the "Tech Info" thread atop this forum for some IAC test ideas & guidence.
I'd also make sure all the engine & body ground connections are clean & tight & that the alternator & battery ouput are up to spec.
More thoughts for pondering.
Let us know what you find.
Just wanted to know before i go down and plop 60.00 on a new IACV. This is 24 years old and never been replaced, just cleaned. Thanks!
Lot of people telling lots of things that could be wrong. So yours only stalls when at stops..mine too, and that's frustrating. I do not have an open checkbook for the whole engine repair, since this is a 24 year old truck. I might go buy a IACV and cross my fingers,better that than to take it to a shop and have them charge me 100.00 to tell me that's the problem,then labor to replace it, when i can do that. Thanks, and good luck!
I bought truck ( from a mechanic) and it had a full tank. What a nice guy I thought! Well after 4 days and when tank got down to a 1/4 it began to act as it currently is now. Thus I tried to adjust the throttle screw which I now know is a no-no (because when I removed air hose to clean throttle plate there is a sticker on the throttle body) saying NOT to adjust, maybe it should more visible. So now I make matters worse and trouble shoot to needing an IAC. But when I put on new IAC it is the same. I now realize it needs a gasket (bear in mind tank is now approaching empty) On the way to pick up gasket I fuel up but it still stalls because it needs a gasket. I replace gasket and problem is solved, truck runs perfect. However I still have close to a half tank of gas. Now I drive the 20 miles I describe and gas is down below a 1/4, starts stalling again. So today while shop has it it is below 1/4 tank the whole time. They get it to exactly where it was when it was feeling like it wanted to stall and I adjusted throttle screw.. I drive for 5 miles experiencing the 'wanting to stall but not stalling" I gas up and it runs great RPM's stay just under 1K when I come to a stop. I do not know what exactly is in the tank but I am thinking it has something to do with a float because when stopping gas would slosh to back of tank or fuel pump is overheating when fuel is low. Would love to hear from the pro's. Hope this makes sense.
Thanks!!!
Nothing makes sense to me on these trucks. They have to learn to play the same tune with all it's instruments, if you will. it takes one sour note and the song is ruined. That said, I removed my IACV once more and did another thorough cleaning using carb cleaner,let it dry, once turning over,it would want to die again,then really really try to catch up, but ultimately stalls.
So this time I hammered the gas to high idle for about ten minutes,then it pretty much held it's own. Drove to the mail box down the street and it ran fine. The true test would be to take it out on the freeway,if I would be so bold. So basically, when it's cold, it stalls,but when I warm it up, it appears to be ok, BUT..I STILL WANT TO GET TO THE BOTTOM of why it just won't idle when I start it up.
Today, I almost went out and bought a $60.00 IACV w.gasket (Autozone) Pep Boys ($110.00+ $19.00 gasket. old one works fine.) I keep thinking it could be Fuel relay,TFI Module, need a brand new IACV, EGR, FPR, or an array of everything combined.
________________________________________
Another thing I did noticed was heavy corrosion of the wires (about 4-6 each) feeding from the bundled chassis wiring harness running alongside the air filter box and into each of the two relays on the passenger side, attached to the fender wall. (Picture below) Haven't called ford to see how much they are.
I have contacted three area FORD salvage years as well as two FORD dealerships and although they have both the FUEL RELAY (the top part # unknown for $59.63) and the Multi-Function relay part number# E(eight)DB13853AA green colored Ford part for $ 48.64) None of these places carry the actual wired-pigtailed bottom section from the wire harness bundle to plug in the above mentioned parts.
