compression test
Old Mar 15, 2010 | 02:32 PM
raptor2005's Avatar
raptor2005
compression test
hello i have been fighting with this truck for a while now and tried a long list of thing in the tech folder for no starts. now i have a few questions 1. how do you preform a compression test and 2. is it true that the truck will still run with a blown headgaskets. I was told by a tech that a compression test will not tell me if i have a blown head gaskets and that the truck will still run with a blown headgaskets. the truck turns over but wont start and it spins at about 200 rpms. thanks in advance
Old Mar 15, 2010 | 04:03 PM
liv's Avatar
liv
On a diesel you test compression by sticking the gauge in the Glow plug hole. Its basically just a pressure gauge if you have weak pressure while cranking then it could be a number of things not just head gaskets. There are a lot easier ways to test for blown headgaskets, such as testing coolant for exhaust gases. An engine will still run with blown headgaskets.
https://www.ford-trucks.com/forums/8...condition.html
read this thread from the tech folder. This is a common problem and there is a lot of information out there about it. Try reading the tech folder or doing a search in the future.
Also you didn't provide any information, but the 6.0 has a 5year/100k mile warranty. If you are still under warranty take it in to a dealer.
bad3andy
Mar 25, 2015 01:08 PM
JESTERxHEAD
Aug 17, 2011 09:37 PM
G2IC_Wraith
4 Cylinder Engines
16
Jan 2, 2006 06:56 PM
timothy47129
Nov 22, 2005 12:33 PM
rutcutterford
May 1, 2001 03:20 PM
