boost numbers with stage 2s?
Old Mar 17, 2010 | 08:36 PM
Talyn's Avatar
Talyn
I dont think i'd trust that mechanical gauge to much.
Old Mar 18, 2010 | 06:59 AM
Neal 97 250's Avatar
Neal 97 250
Originally Posted by bruno2
what is a hx50 turbo? Is it a ball bearing turbo? If so is it a drop in?
The hx50 is basically the same thing as a H2e turbo. I believe the connections are slightly different.
No they are not a ball bearing turbo either. Just a rather large turbo that is capable of withstanding way more than the stock one. They give pretty high boost numbers with the right amount of fuel.
What is wrong with a mechanical boost gauge? I have two and have no problems. It is like having a direct link to the engine.
Old Mar 18, 2010 | 08:25 AM
Talyn's Avatar
Talyn
nothing wrong with them, but its really easy to kink the boost line.
Old Mar 18, 2010 | 10:20 AM
Neal 97 250
Use copper and that won't happen
Old Mar 18, 2010 | 10:24 AM
Talyn's Avatar
Talyn
Never thought of using coper tubing, thats pretty neat Idea Neal!
I personally like the EV2 setup though, its simple and practical. Sensor sends readings to gauge, gauge interprets. No room for error, which is what I like.
Mechanical gauges can eventually fail as far as I can tell. There has to be some sorta pressure system inside the gauge that reads the line pressure.
But electronic ones can do just the same, the sensor can fail.
Old Mar 18, 2010 | 10:29 AM
Neal 97 250
My point exactly.
Is one better than the other?
Probably not.
Old Mar 18, 2010 | 10:46 AM
Talyn's Avatar
Talyn
Unless your measuring in Inches of Water, I think we are both at a loss on either end. =)
The mechanical one should respond a bit faster than the digital, but the digital IMO would be slightly more reliable.
So, it seems like a tie to me.
That would be funny though, getting in a truck with a tube of water. "WTF is that!?!?"
Dude, thats my boost gauge, I wanted accuracy.
