Hello all. Well I did it. Bought my first powerstroke. LOve it already. Heres what I got. 2000 F250 crew 4x4 XLT.
For some reason my power mirrors now dont work. Did when I bought it 3 weeks ago but now nothing.
Replaced the switch. Nothing.
Fuse 4 is fine. Underhood light works. Glove box light works. No power to mirror switch. The only thing I have done to the truck is "fixed" the power door acuators by doing the unserviceble service to the actuators. Power door locks work fine. NO map lights at all but the dome lights are fine. Any Ideas? I am fresh out. Thanks in advance.
Your right, the fuse is #4 10 amp, and the power comes out on a lightgreen yellow. There should be a plug inside the driver's door (c550) where you can check for power.
If it's dead, and you said your glovebox light works, then there must be a break in the wire, possibly in the door jamb area.
Power comes out of fuse 4 on a lightgreen/yellow, and then goes to a splice. The power then branches to the plug inside the door, the glovebox light, the map lights, and the engine compartment light.
