Sponsored by: Real Truck
Leveling Kit?
Old Mar 14, 2010 | 02:22 PM
jjsniper32's Avatar
jjsniper32
Leveling Kit?
I have a 2008 F-250SD Lariet and I am about to put 33's with slight offsets on it. The truck came new from Ford and it measures out level to the ground on front and back and doesn'r seeem to have a factory rake on it. I had plenty of trucks in my day but this one seems to be the best so far. The Super Duty Shop I know well here says that I could go with or without a leveling kit with the 33's. Has any one had any issues with not installing a leveling kit on a 08 6.4L 250SD? I'm wondering if really need it or not.
I know the 33's will not rub with a small off-set rim, but just want to make sure I'm not wasting my time or money on a leveling kit.
Thanks,
JJ
Old Mar 15, 2010 | 05:49 PM
kato56's Avatar
kato56
re: Leveling Kit
I would think if you don't believe the tires will not rub and there is no rake, I would save my money.... I invested in a front end leveling kit for my 2006 F350 SD LB FX4 because of the rake, but noticed a slight steering wheel shimmy after since I did not invest in new track arms brackets to lower to tie point on the frame. I decided to live with it and not spend more $$$$ for adding the brackets.
Old Mar 15, 2010 | 06:45 PM
midnightrider32's Avatar
midnightrider32
I have an 08 that sits pretty level(visually, and measuring). I contributed that to the fact that I have the camper package which includes beefier coils, and the fact that I have the 5.4L. I just installed 305/65R18s on my truck and they don't rub at all(no leveling kit). They are roughly 34x12". I have a pic or two in my gallery if you would like to see.
Old Mar 15, 2010 | 08:15 PM
DAVE67FD's Avatar
DAVE67FD
Not having your truck realigned after the leveling kit will lead to increased wear on your Ball joints, tie rods etc.. Investing in a quality alignment is imperative. The alignment shop may request caster/camber shims. Lifting/leveling done properly can be pricey.
Old Mar 16, 2010 | 09:17 AM
SuperDutyScaler's Avatar
SuperDutyScaler
if i find the thread and if i trade in my 04 for a newer truck probally not i would install this, kinda pricey but its so worth it
Old Mar 16, 2010 | 09:24 AM
midnightrider32
Are you talking about the icon leveling kit? It's like 1400$, but it lifts the front and rear about 2-3". Seminaryranger has it on his 09. Pretty sweet if you have the money.
Old Mar 17, 2010 | 09:44 AM
SuperDutyScaler
yes thats it, if i get a newer truck ill throw it on something mild that rides and looks awesome
Jamon_23
Mar 18, 2015 07:37 AM
Dirtyweekender77
Jul 17, 2014 10:47 PM
bakerbuilttracks
Dec 4, 2013 10:23 AM
02 Stroker
May 12, 2013 08:07 PM
06silvercrew
Sep 22, 2010 11:23 AM
