WTF, More trouble
Old Mar 13, 2010 | 09:56 PM
truckerboy's Avatar
truckerboy
WTF, More trouble
Ok, im really starting to get pissed at this 29 year old piece of s*** called a truck. I have pulled every single engine componet, with the exception of the main bearings and the pistons (the connecting rods, pistons, and connected parts), and the crank.
So, i am attempting to push the piston (#1) up through the top of the motor. It will go to TDC, but then stops. What is goin on here, and is there a way to solve it without an expensive tool that i will not know how to use, then have to ask someone, proceed to get angry pull the truck to the garage where a pro. will make it look so damn easy.
Quite frankly, i am fed up with these tools (up to $1496 already) and how to use them.
And the engine is still in the truck. (pulled the oil pan by unbolting the motor mounts at the frame, putting a jack under the oil pan ((with a block of wood on the jack)) the jacking the motor up and putting a 2x4 under the motor mounts between the mount and frame.)
Old Mar 13, 2010 | 10:19 PM
Harte3's Avatar
Harte3
Did you remove the ring ridge from the cylinder walls?
Old Mar 13, 2010 | 10:21 PM
truckerboy's Avatar
truckerboy
the What??
I have no idea what that is, before this the farthest down i have been into a motor was the valve cover gasket.
Old Mar 13, 2010 | 10:27 PM
tlk50's Avatar
tlk50
You have a ring groove at the top of the cylinder wall that the ring is hitting. With a piston down in the block feel the cylinder wall right at the top you'll feel the edge of the original bore hole. Disconnect the rods from the crank (put the rod cap and nuts back on the rod they came off of and in the same direction) take the crank out if you want, and drive the pistons out with a hammer handle or a block of wood on the rod cap. If you had a ridge reamer it would make it easier but they are not cheap and I see your not into buying more tools. You might break a piston but it sounds like your going to have to get it bored anyway and that means over sized pistons.
Harte3's Avatar
Harte3
Over a period of time, the rings wear the cylinder wall up to piston TDC just below the top of the cylinder. That ridge must be removed in order to get the piston out the top as the rings will catch on the ridge.
Old Mar 13, 2010 | 10:28 PM
arctic y block's Avatar
arctic y block
Stick yer hand in the cylinder and at the top where the piston is stopping you will feel a lip. It's the ridge left from the piston wear. It must be removed with a cylinder hone or ridge reamer.
Old Mar 13, 2010 | 10:30 PM
arctic y block
Hehehe a lot of posting going on there all at once
Old Mar 13, 2010 | 10:31 PM
truckerboy's Avatar
truckerboy
will it come out through the bottom?
And if si how am i to go about removing the crank without disconnecting the trans. Also, will this cause problems with the clutch?
Old Mar 13, 2010 | 10:32 PM
truckerboy's Avatar
truckerboy
Yea, and its all sayin the same thing.
Old Mar 13, 2010 | 10:37 PM
Harte3's Avatar
Harte3
What? There is a consensus here?
Old Mar 13, 2010 | 10:52 PM
truckerboy's Avatar
truckerboy
Yep, i need yet another tool, and there is a lip thing at the top of the cylinder wall
Old Mar 13, 2010 | 11:45 PM
arctic y block
Get a cheap cylinder hone. The kind with ***** not flat stones. Hone the cylinders just at the top with the intention of tapering the ridge. Just a minute or so and it will fall out. But don't pull the damn hone out of the hole when it is spinning cuz ya will only do that once
DSMMH
Dec 20, 2018 04:13 PM
Chevy Guy Gone FORD
Oct 30, 2013 08:47 PM
boxtruckgene
Oct 7, 2012 11:56 AM
cactusbronco
Jun 14, 2012 08:33 PM
njjeeper
Apr 13, 2007 02:32 PM
