Alive again!!!!!
Old Mar 13, 2010 | 11:56 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by crazymut
Stop waiting is all I have to say. I took mine out do to the trans change planning on sending it in for reflash, almost four months later I finally have it back in. And yes I believe the down shifting is with Jody's updated tuning.
Actually I will be getting new tunes before live tuning because I have to send it in to get it reburned for single shots I'll be installing before I head to RRW.
Old Mar 14, 2010 | 01:59 AM
Stewart_H's Avatar
Stewart_H
You all showed up about five min before I left. I left about 1:15
And you didn't even say "hey"!!
Was your truck the other dark blue one that was parked next to Monty's truck?
Stewart
Old Mar 14, 2010 | 03:12 AM
homesteader's Avatar
homesteader
Went to Modesto to see Jody (DP Tuners) today. Great group of guys, and gals there. I had my chip reburned for the John Woods trans. She is alive again. Shifts totally different than without the chip, at least while slowing down. When it shifts out of overdrive it feels like someone pushed the overdrive kill switch and there is a very firm solid shift down. Almost like it is a stick shift. Great to have the power back.
Terry why did you replace your trans? Did you have one with manual diode? Which trans did you get? JW trans is on my mod list.
Thanks Roger
Old Mar 14, 2010 | 02:18 PM
crazymut's Avatar
crazymut
Stewart
I said hey, everyone was buisy getting a bite to eat though. Yes mine was the other dark blue xcab.
Old Mar 14, 2010 | 02:23 PM
crazymut's Avatar
crazymut
Thanks Roger
The reason I got a new trans was due to my old one had a diode not functioning properly and it was getting to where it was starting to slip. On top of not wanting to shift into second gear. I got John's towmaster trans. Now with DP tunes it is shifting very nicely. Are looking for a replacement trans or a performance trans?
Old Mar 14, 2010 | 07:27 PM
homesteader
Hey Terry wasn't sure if you where asking me if I was looking for a trans. If so yes just trying to get a feel what is out there. Would you recommend a replacement or a perfomance trans. What is the towmaster trans a performance trans?
Old Mar 14, 2010 | 11:38 PM
crazymut's Avatar
crazymut
The Towmaster is John's entry level trans. Although entry level it is much stronger than stock. Also the diodes are elemenated, so no diodes going bad. Here is a link John Wood Automotive - Home Check it out, it will tell you more than I can, other than I am so far completely satisfied with what I got.
Justin Jantzen
Oct 6, 2014 07:17 PM
3Mike6
Jan 1, 2010 12:27 PM
f2501967
N. California Chapter
Mar 8, 2008 10:13 AM
Adam_C
Oct 5, 2004 10:42 AM
Adam_C
Aug 16, 2004 12:00 PM
